Access door wont access
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xtopher, Oct 24, 2015.
  1. Oct 24, 2015 at 10:16 AM
    Xtopher
    Xtopher [OP] Active Member
    Pennsylvania
    08 Tacoma
    My passenger side access door wont open. Somehow the linkage to the handle came apart inside the door, and now the handle just flops in the breeze.
    Has anyone else had this problem?
    Before I start digging and break something I figured I'd ask for advise.
    TIA
  2. Oct 24, 2015 at 6:00 PM
    spp
    spp OC, Kalifornia
    OC California
    There is another thread about this but I don't have time to search for you right now.
  3. Oct 25, 2015 at 6:03 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The linkage is likely not broken. There is a wedge shaped locking lever between the doors ( on the access door below the striker plate ) that disengages the handle when the doors are all closed. It is stuck in. Look at the other side doors and you will see the wedge.
    Hit it with your hand and it may pop out. Or remove it and get it loose.
