Accessing Contact List while driving ...
Discussion in 'Audio & Video' started by Bobcape, Nov 15, 2013.
  1. Nov 15, 2013 at 11:53 PM
    Bobcape
    Bobcape [OP] Well-Known Member
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    I have my iPhone BT'd and can play music and make phone calls. No problem. Is there a setting, tweak or work around that will let me access my contact list (phone book)while the truck is moving? Thanks.
    Bob
  2. Nov 16, 2013 at 11:09 AM
    tonytsai0429
    tonytsai0429 Well-Known Member
    SoCal
    Racy Inferno
    What phone you are using?
    My iPhone can do that contact search and call history without problem!
  3. Nov 16, 2013 at 1:23 PM
    Bobcape
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    IPhone 4s. My head unit does not have nav. I can access the phone book when I'm stopped, but as soon as I start moving it says it is not available. I've found list of articles on it, including another thread on it here. But no solutions yet.
    Bob
  4. Nov 18, 2013 at 11:59 AM
    tonytsai0429
    SoCal
    Racy Inferno
    interesting Bob...let me try when moving...usually i search my history calling list rather contact....perhaps, I can only access into my call history rather the contact list.
    will update my finding later today
  5. Nov 18, 2013 at 12:08 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    You could do what I did with my pioneer. I used a toggle switch to act as the parking brake to override the system so I could daces things while not in park. I don't know if this is possible with the stock one.
  6. Nov 18, 2013 at 12:08 PM
    CilantroDoomTaco
    CilantroDoomTaco Well-Known Member
    Lake Superior
    06 DCSB
    I'm in the same boat... as near as I can tell, only the call history is available while in motion.
  7. Nov 18, 2013 at 12:14 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    If your head unit allows you to do while stopped then the simple/cheap answer is to trick it through wiring. On the back of the unit they'll be a wire what's run to your neutral switch, if you simply connect this to and local ground it will make the head unit think you're always in park and so you'll have full access to unit all the time.
    The same thing is done for units with nav/video capability when people want to run video while driving for whatever reason (yes there are times this actually makes sense..)
    There are divides you can get off eBay/Amazon for cheap but they effectively do the same thing and this option is free.
    NOTE: the "neutral switch" I mention here is not neutral in wiring terms but the physical switch on the transmission that let's functions of the vehicle know if you're in gear or not.
  8. Nov 19, 2013 at 6:10 AM
    Bobcape
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    It's not actually looking for neutral or park on the transmission as I can be stopped in drive and still access the phone book. Actually I can see it at like 1 or 2 MPH. Any faster and it says it isn't accessable. The work around for me so far is to grab the phone and use Siri to voice dial. Sometimes my phone is not easy to get to while buckled up. I'll just learn to work with it.
    Bob
  9. Nov 19, 2013 at 9:50 AM
    NewRider
    Travis
    '87 4runner
    That I've never heard of but the work-around should be basically the same. If you've still got the installation guide for the stereo, look at the wiring diagram and it should tell you what each wire is for. Obviously now I'm not goin to be able to tell you which one to look for, a little intuition will help here.
    Could you list the model stereo?
  10. Nov 19, 2013 at 10:25 AM
    CilantroDoomTaco
    Lake Superior
    06 DCSB
    Bone stock base model Toyota stereo here. I assumed Bobcape had the same.
  11. Nov 19, 2013 at 12:28 PM
    NewRider
    Travis
    '87 4runner
    Oh is this a function of the new (2012+) factory units? My '06 wasn't capable of connecting to anything until I modded it... And if it is factory, I'm sure they'll still be a way of getting around the issue that will probably be a simple wiring fix
  12. Nov 20, 2013 at 5:52 AM
    Bobcape
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    Same-same for me. The base model factory Display Audio (not e-tune) unit. It works fine BT'd playing music and placing and receiving calls, it just restricts access to the phone book when moving. I can see my speed dials and call history when moving but not the phone book. I tried this - I stopped and opened the phone book so I could scroll through and then started moving. It closed the phone book and displayed that the phone book is not available while driving.
    I just thought if there was a settings change I could make I would do that. If not I'll continue to use Siri for voice dialing if I need to. Thanks.
    Bob
  13. Nov 20, 2013 at 10:59 AM
    NewRider
    Travis
    '87 4runner
    I can garuntee that it won't be a settings feature. The reason they do this is to make the phone "hands-free" and "safe" so the only way to get around it will be wiring it so it thinks you're always stopped... If it's not critical to you then ya, I'd just keep doin what you're doin.
  14. Nov 21, 2013 at 11:40 AM
    tonytsai0429
    SoCal
    Racy Inferno
    I think it would be awesome to activate Siri on the screen! Just sayin!
