Accessory Power for Stock Switches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalover06, Aug 18, 2025.
  1. Aug 18, 2025 at 6:11 PM
    tacomalover06
    tacomalover06 [OP] Member
    Does anyone know where the stock switch's (i.e diff lock, rear outlet, fog lights) get their power for illumination when you turn on the lights? I was trying to find a wiring diagram online but wasn't able to find one, and while I could trace the cables the position of the switches makes it pretty hard to trace without removing half the dash. I ask because for some reason the switches do not illuminate when I turn on the lights(as they should), but my power window button does illuminate, and since the previous owner has been messing around with the cabin fuse box it wouldn't surprise me if he cut a cable or something along those lines.
    Note: 2006 Toyota Tacoma 4x4 TRD-OffRoad (stick-shift if it matters)
  2. Aug 18, 2025 at 6:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The Inverter switch isn't illuminated, the others get Power from the Tail Fuse (10A) via the J2 Junction Connector on Pin 1 (Green) and Ground from the Rheostat via the J3 Junction Connector on Pin 2 (Green/White).
    If you tail lights work your Tail fuse is good.
    Does your other backlighting work on the HVAC controls and such?
  3. Aug 18, 2025 at 6:26 PM
    tacomalover06
    Yes all my other backlights work with the exception of the rear differential lock, and the fog lights and not the rear power if it isn’t illuminated
  4. Aug 18, 2025 at 6:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Could just be burnt out bulbs, check voltage across Pin 1 (Green) and Pin 2 (Green/White) at the switches with the tail lights on.
  5. Aug 18, 2025 at 6:47 PM
    tacomalover06
    You my friend are a genius. Measured 13.7 V across the two pins with the truck running and the lights on. Any good OEM quality replacement recommendations or shall I have to resort to eBay hunting?
    Edit: Also found something interesting, when I first took off the Rear diff lock switch and reconnected it the light did illuminate for a second or so but then turned off. After trying to replicate what happened by unplugging it and replugging it I was unable to.
  6. Aug 18, 2025 at 6:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm coming up with 90011-01058
    You can put your VIN in here and look them up to confirm.
    https://partsouq.com/en/catalog/genuine
  7. Aug 18, 2025 at 7:05 PM
    tacomalover06
    Yep I get the same. Thanks!
