accessory power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeftCoastNerd, Mar 30, 2016.
  1. Mar 30, 2016 at 12:34 PM
    LeftCoastNerd
    LeftCoastNerd [OP] Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    I looked around the FAQ's, and didn't see anything really addressing this.
    I'll be wanting to add some always-powered accessories to my taco (2008 access cab trd offroad), initially some LED lighting in the camper shell I just put on, and eventually some audio upgrades...
    whats standard practice? do you guys just run your own power wire right off the battery + clamp? or do you take it off the +12 stud in the main fuse box? or is there some better place to access this?
    specifically for my camper shell LED Lighting, I was toying with putting a spare 12V sealed 20AH battery I have back there somewhere, and hard wiring it to the trailer hitch "BATT", and running my LED lighting off that battery. this way I *can't* kill the vehicle battery when dry camping, and the engine recharges said battery any time I'm driving... I'd probably also put some aux 12V power outlets hooked up to this same battery.
  2. Mar 30, 2016 at 2:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Mar 30, 2016 at 2:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Thats actually a great idea! I shouldnt of thrown away my lil battery that came out of my trailer.
    But realistically, its gonna be hard to kill the truck battery with some leds.
    I personally ran a constant hot from the battery down the firewall along the driver frame then into the driver side rear bed cubby. Then i went off from there with a 12v socket, a high amp 12v connector for my big accessories, as well as my LED lighting. Having a constant 12v hot back there is probably the most used mod I have done to my truck.
  4. Mar 30, 2016 at 2:39 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
  5. Mar 30, 2016 at 4:17 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    subd for ideas
  6. Mar 30, 2016 at 6:56 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    hey, just stumbled on this stuff.
    http://www.amazon.com/U-Shape-Aluminum-recessed-installation-Mounting/dp/B00VUAYFW8
    I'm thinking that kit of 5 1m pieces and my existing tape is perfect. the roof of the cap is about 60" long, so splice two pieces together, and cut to length, secure them on the inside of the top just outside the ridge on each side, lights facing straight down. run my RGB LED strips, put the power module in a little pod about where the current dome light is, so thats the 'target' for the color choosing remote control...
  7. Mar 30, 2016 at 7:12 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    the LED tapes I have are these,
    thats a 5m reel with 60 RGB led's per meter. its 1.2 amps/meter with R+G+B on high (bright white).
