Accidentally Drained Trans Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blowchunks, Aug 4, 2019.
  1. Aug 4, 2019 at 5:54 PM
    blowchunks
    blowchunks [OP] New Member
    Samuel
    07’ Tacoma
    well, i tried to change my oil (first time ever) on my 07’ Tacoma, got underneath the truck and badabing badaboom, loosened the drain plug to my transmission instead of my oil. It drained a total of about 2.5 quarts before it was done. what do i do?
  2. Aug 4, 2019 at 5:57 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Put 2.5 quarts back in? Not being a smartass, that's what I would do.
    Welcome to TW!
    Hobbs, Gunshot-6A, DrFunker and 2 others like this.
  3. Aug 4, 2019 at 5:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah what he said. Measure how much you took out, and put it back in. If the container you drained into was clean just dump the same stuff back in
  4. Aug 4, 2019 at 5:58 PM
    blowchunks
    Samuel
    07’ Tacoma
    does the engine not have to be running or at a certain temperature to do that?
    also there’s no trans dipstick idk if that changes things ?
  5. Aug 4, 2019 at 6:03 PM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    If the container was clean and you didnt spill any, yes, put it back in. I'd try to get new fluid if you can. Carquest used to stock it. Otherwise learn the procedure to put the truck in check mode, fill the fill plug, get truck to proper temp, and drain overfill plug. Instructions are in more than one thread.
    Gunshot-6A likes this.
  6. Aug 4, 2019 at 6:08 PM
    ajm
    Anthony
    AZ
    1996 4x4
  7. Aug 4, 2019 at 6:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    :ohsnap:
    Not again.
    Sandman614, dome, tomwil and 3 others like this.
  8. Aug 4, 2019 at 6:14 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    might as well do the trans now,
  9. Aug 4, 2019 at 6:17 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The engine doesn’t need to be running to put what you took out back in. If you dumped it in a dirty bucket, do not put it back in, any grit in the bucket is a bad thing. Follow the link provided above and use new fluid.
  10. Aug 4, 2019 at 6:22 PM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    When the FJ Cruiser 1st came out lots of guys did the same thing. Including adding 5.5 qts. of oil on top of the 5.5 qts. of oil that was already in there. At least you caught it and aren't stranded.
    blowchunks[OP] likes this.
  11. Aug 5, 2019 at 7:19 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    If the container you drained the fluid into was clean, then just put it back in. If it wasn't, then measure what drained out and out the same amount back in.
    What's your mileage? Might be time to get some new fluid in there anyway.
  12. Aug 5, 2019 at 7:22 AM
    DrFunker
    DrFunker Well-Known Member
    Welcome to TW OP. :wave:
  13. Aug 5, 2019 at 8:21 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Toyota should have put some type of placard on the trans pan......
  14. Aug 5, 2019 at 8:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They did, unfortunately it was located behind the drain plug.
    Once removed, the warning is evident by a red/pink fluid with distinctive smell different that engine oil.
    Lol.
    It happens. Fill it back up. And drive on.
    Blockhead, Monkeybutt2000 and ajm like this.
  15. Aug 5, 2019 at 8:33 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Ha! After teaching my boy how to change the oil on his '07, I got underneath with a white paint pen and wrote "NOT THIS ONE" with an arrow pointing to the trans drain plug.
    crf69 and TnShooter like this.
  16. Aug 5, 2019 at 6:36 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Reading about this error several times here, I bot a can of red spray paint, took the truck to some one who knows the difference between transmission and oil drain plugs, and we sprayed to hell and back the oil plug......end of problem.........
  17. Aug 5, 2019 at 7:40 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  18. Aug 5, 2019 at 7:43 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
  19. Aug 5, 2019 at 7:56 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Look at it this way, at least you didn't drain the whole trans, double your engine oil and drive it around for a few days (happens more often than you think).
    I still for the life of me can't understand how this happens to people lol, but at least you caught it and you'll definitely know better next time.
    Just add in what you took out and you'll be good to go
    Welcome to TW :cheers:
    blowchunks[OP] and Jimmyh like this.
  20. Aug 5, 2019 at 8:03 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
