Accidentally drove with rear differential lock engaged.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roryrover119, Feb 14, 2024.
  1. Feb 14, 2024 at 9:47 PM
    Roryrover119
    Roryrover119 [OP] New Member
    2005 prerunner TRD off road
    Hello,
    Today I accidentally turned on my rear differential lock before leaving my driveway. I drove with it on going about 45 mph for 5 minutes and making a few sharp trurns before I turned it off while fully stopped after noticing. Did I do any damage to the differential?
  2. Feb 14, 2024 at 9:57 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    As long as you don’t see smoke or smell burning you’re good I would be more concerned about driving in 4low which I’m assuming you did unless you have an aftermarket locker or did the grey wire mod
    Nm I see you’re a prerunner
    TS4x4 likes this.
  3. Feb 15, 2024 at 3:52 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    No, just some increased tire wear.
    If you can go rockcrawling on sandstone in moab with an overloaded overlander... you are going to be fine with some street time.
    TS4x4 likes this.
  4. Feb 15, 2024 at 4:39 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
  5. Feb 15, 2024 at 5:54 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    Dangit, I was trying to make it in the thread to say "In before 'Part out' "! :D
    (Yeah you should be fine, especially without having to worry about 4x4)
    TS4x4[QUOTED] likes this.
  6. Feb 15, 2024 at 6:03 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    You're fine
  7. Feb 15, 2024 at 6:30 AM
    Bishop84
    Bishop84 Well-Known Member
    Lots of Toyotas have welded diffs or spools on stock axles. They daily like this. It's fine.
    Especially because the tires will slip if the axle starts to bind too much. Usually a chirping noise.
    Enjoy the benefits of a Toyota truck. They are durable.
    4x4spiegel and ZColorado like this.
  8. Feb 15, 2024 at 12:20 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I thought you had to be in 4lo to turn on the diff lock. If that’s true then you pressed the button but didn’t engage diff lock. You would have had a blinking red 4x4 button icon on the panel.
    No way you were going 45 with 4lo engaged.
  9. Feb 15, 2024 at 12:21 PM
    IEsurfer
    Socal
    He has a 2wd trd off road those come with a locker but no 4wd
    Hook78[QUOTED] likes this.
  10. Feb 15, 2024 at 12:22 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Ohhh prerunner duh. Thanks.
  11. Feb 15, 2024 at 2:53 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I thought it automatically disengaged at speeds over 10 mph.
    Not something I'd do on a regular basis anyway. Long term you'll wear out stuff prematurely. But for what you did I wouldn't worry about it.
  12. Feb 15, 2024 at 2:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Nope, if its locked its locked.
    OP was it a flashing light or on solid on the dash? If it was flashing it was never actually locked.
  13. Feb 15, 2024 at 3:06 PM
    Roryrover119
    I'm pretty sure it was locked I don't remember it flashing.
  14. Feb 15, 2024 at 4:42 PM
    TacoTuesday1
    FL
    probably not. Next time you change the gear oil it’ll be a bunch of crap coming out or look fine. It’s either gonna start acting up now or it’s not.
    and, there’s used working diffs out there for a whopping 50 bucks.
