Accidentally put in half a quart of MT-90 into rear diff. Is it ok?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mikeyy777, Jan 17, 2016.
  1. Jan 17, 2016 at 2:55 PM
    mikeyy777
    mikeyy777 [OP] New Member
    Hello,
    I just got a 2000 Tacoma and was going about changing all the usual fluids (engine, diffs, trans, crank case).
    Was already tired when I was filling the rear diff, and accidentally put in about half a quart of Redline MT-90 oil before I noticed! I filled the remainder with Redline 75w90 but am now worried if it's going to be ok? or if it's safer to dump everything out of the rear diff again and refill with 75w90 only? It's an expensive mistake but I'd rather not mess anything up in the future. I plan to have this truck reliably running for the long haul.
    I've read that MT-90 can be detrimental in the differentials and should only be put in the transmission, but have found no concrete answers.
  2. Jan 17, 2016 at 2:56 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Dump and refill
    JDM and DustStorm4x4 like this.
  3. Jan 17, 2016 at 2:59 PM
    mikeyy777
    What's the damage? Can I drive on it for at least 100 miles?
  4. Jan 17, 2016 at 4:23 PM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
  5. Jan 17, 2016 at 4:26 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I wouldn't drive it. Screw that. Would you rather buy $20 bucks in liquid or $100s of bucks in new diff and labor to replace?
  6. Jan 17, 2016 at 4:32 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I'd drain and refill asap. When the diff gets hot, crazy shit could happen. $$$$$
    DustStorm4x4 likes this.
  7. Jan 17, 2016 at 4:42 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    It's not the end of the world, but I wouldn't leave it in there any longer than you had to. A GL-4 oil does not have the additives that provide the protection that diff gears need. Since you mostly filled with a GL-5 oil, you are probably OK to drive to the store to get more. I'd worry if there is any strange reaction between the two types of oils. Anyway, don't be too worried about it, just get it changed soon.
  8. Jan 17, 2016 at 4:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    MT 90 is a 75w90 gear oil. You aren't going to blow anything up for a few days.
    However, it is GL4, and your diff wants a GL5. The GL4 is for the trans, and is protective of brass syncros.
    While you can spend the $ as you see fit on product, I'd suggest you just get some OTC Mobil 1 75w90 GL5 and do your change. Cheaper, easy to find, quality product.
    The next time you do a trans fluid change give Ford XT-M5-QS a try. I've seen it make shifters that were notchy even with Redline work like butta. Be careful at the Ford dealer. Some of the parts guys might try to slip you something else. Unless you have some SVO jocks in your area, it's likely they'll have to order in the fluid for you.
    CodeSeven likes this.
  9. Jan 17, 2016 at 5:04 PM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
    The potential problem of running MT-90 in your differential is not its weight, but its rating (GL-4). It is not designed for the pressures of a differential.
    Personally, I would change it and not take the risk of causing any damage. If you do have to drive it, post again after you change it and let us know if there was any metal on the magnet...that could be useful information for someone down the road in the same situation.
  10. Jan 17, 2016 at 6:41 PM
    mikeyy777
    Ouch. I've driven about 50 miles on it already, will try to get it changed ASAP and not drive more than I have to.
    Will report back on the metal shavings..
  11. Jan 17, 2016 at 6:44 PM
    Tacogram
    Tacogram Well-Known Member
    Apple Valley. CA
    Go do it right now man.
  12. Jan 17, 2016 at 6:58 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Mikey don't worry. you have a GL4 75w90 gear oil in your diff that almost meets the specs of what youre supposed to have. you can go a few thousand miles so long as youre not putting serious load on your truck.
    but you should change the oil for a GL5 the very moment you have a chance to, and no later. Also, you'll need new washers, don't forget that.
    Norton likes this.
  13. Jan 17, 2016 at 7:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't hammer it and you won't find a thing.
  14. Jan 17, 2016 at 7:56 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Though really, if it was just light driving, youll be fine. Just drain and refill.
    billybob50 likes this.
  15. Jan 17, 2016 at 8:06 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to all of this ^^.
    I doubt POTENTIAL damage would be immediate or severe, but Toyota specs specifically call for GL-5 gear lube in the differentials. As noted by others, the primary difference between GL-4 and GL-5 is the amount of extreme pressure additive package. GL-4 has less than GL-5 provides, so you're less protected against harsh use. Go easy on it and change it out as soon as you can.
    Wulf and CodeSeven[QUOTED] like this.
  16. Jan 17, 2016 at 8:14 PM
    CodeSeven
    Serge.
    Coachella Valley
    Yes, that's right! GL-5 became full Hypoid-Gear (spiral beval vs standard gear) oil, that's really the only difference. It handles higher pressures from the spiral beval. Just don't push your truck.
  17. Jan 17, 2016 at 8:18 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Y'all need to chill, it'll be fine.
  18. Jan 20, 2016 at 11:22 PM
    mikeyy777
    It does appear to be fine.
    Got it changed today with no apparent adverse effects.
    The magnet on the drain plug did not have anything on it. This is after about 60 miles of driving with half a quart of MT-90 mixed in.. it has been an expensive oil change!
  19. Jan 21, 2016 at 8:40 PM
    flying_az
    Scottsdale, AZ
    That's good to know, thanks for posting.
  20. Jan 22, 2016 at 10:24 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    agreed, you guys are really over reacting.
