Accidentally used wrong oil and didn't catch it
Discussion in '3rd Gen. Tacomas (2016-2023)' started by poshmick907ak, Oct 29, 2022.
  1. Oct 29, 2022 at 10:31 AM
    poshmick907ak
    poshmick907ak [OP] Member
    So In cleaning my garage I just caught that I used the container of 5w-20 intended for my wife's car instead of the 0w-20 intended for my 3rd gen Tacoma last time I changed the oil. I've driven 450 or so miles since the change and am immediately changing it now to the correct 0w-20. How bad did I likely just hurt my engine?
  2. Oct 29, 2022 at 10:35 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    It's totally fine. Hotter climates like Mexico use 5w-20 from the factory. You did zero damage.
  3. Oct 29, 2022 at 10:36 AM
    poshmick907ak
    Haha, thanks. That's the response I was looking for. I found some older discussion threads where some people were talking about preferentially running 5w-20 in their Tacoma's during some seasons, so that makes me feel a lot better that it's really not a big deal.
  4. Oct 29, 2022 at 10:36 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    You can use up to 15w-40 as long as ambient temp is not lower than 10F. You are perfectly fine. 0W-20 is a fuel economy choice.
    Wulf and jasonct like this.
  5. Oct 29, 2022 at 10:36 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Haha. It’s ok you should look up what those numbers mean.
    Anton338 and wilcam47 like this.
  6. Oct 29, 2022 at 10:50 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's totaled.
  7. Oct 29, 2022 at 11:00 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    :burnrubber:
  8. Oct 29, 2022 at 11:03 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I don't see any issue using 5w-30 even.
    azreb and Plain Jane Taco like this.
  9. Oct 29, 2022 at 11:04 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I wouldn’t even bother draining it. Just run it to your next change interval.
  10. Oct 29, 2022 at 11:10 AM
    soundman98
    NW Indiana
    the only issue is your warranty coverage if toyota finds out.
    *this just happened on toyota 86 forums. guy was tracking a brand new 2022 86, replacing 0-20 oil with 5-30 as all the arm-chair experts say is required for track use. blew motor, warranty coverage denied, citing wrong oil weight, and aftermarket oil filter installed.
    juries still arguing if whether any of that really had any part in the engine failure, but toyota found a reason not to cover it...
    bulalo likes this.
  11. Oct 29, 2022 at 11:12 AM
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    The “0” in 0W-20 is the flow rate in Winter. The “W” stands for winter, not weight as is commonly thought. 5W-20 and 0W-20 act exactly the same way when warm. 0W-20 will flow better using less hp in cold climates which equals less fuel consumption over the lifespan of the vehicle.
  12. Oct 29, 2022 at 11:15 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Ehhh… 5-20 won’t blow a pickup engine.
    maineah and soundman98[QUOTED] like this.
  13. Oct 29, 2022 at 11:25 AM
    maxmk8
    How would they know ? No tech is going to go and send oil to a lab to determine weight when/is the engine blows up
    wilcam47 and DrabT100 like this.
  14. Oct 29, 2022 at 11:27 AM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Part it out
    Anton338, wilcam47, zacinnc78 and 2 others like this.
  15. Oct 29, 2022 at 11:29 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's the same weight oil once it's warmed up. 0w20 will just be better for cold starts. you're fine. just put in 0w20 next time.
  16. Oct 29, 2022 at 11:40 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is a trick I used when I had different weight oil in my garage. I would spray paint the outside of the box holding the bottles of oil the color of the respective vehicle. Won’t work if you and your wife drive the same color vehicles.
  17. Oct 29, 2022 at 11:43 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I’m really surprised no one has told you to get the truck towed home, get a sample and send it to Black Stone for a full analysis…. Because Tacoma World
    Chaosh1, mello03, wilcam47 and 12 others like this.
  18. Oct 29, 2022 at 12:32 PM
    maxmk8
    I suppose that’s easier than reading the god damn label
  19. Oct 29, 2022 at 12:50 PM
    TA2016
    Oregon
    Very true about reading the label. For me back then it was like “belt and suspenders”. I never put the wrong weight oil in but I have grabbed the wrong bottle out of the wrong box at times (before my paint idea).
    Now every vehicle in my family is a Toyota product and all use 0w-20.
    Somebody Else likes this.
  20. Oct 29, 2022 at 1:13 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Outside the us they put 5-20 in the same engines.
