Accumulator Delete Kit - SOLD OUT - No More Kits
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Trident904, Dec 20, 2018.
  1. Dec 19, 2019 at 6:28 PM
    #361
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    great kit @Trident904 !! These trolls just dont get it with their mickey mouse autozone parts thrown together.... leaks will be coming to yall
  2. Dec 20, 2019 at 5:38 AM
    #362
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    @Trident904, just want to thank you for my kit. Went in just as advertised and all the tips along the way regarding installation and bleeding got me through the process without a hitch. I really appreciate the engineering that you saved me - worth every penny :thumbsup:
  3. Dec 31, 2019 at 11:22 AM
    #363
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    Currently in the process of installing my kit. I would just like to add to the thread that the exhaust bracket bolts are a BITCH to break loose
    Norton likes this.
  4. Dec 31, 2019 at 1:08 PM
    #364
    Trident904
    Trident904 [OP] Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    can be done without removing the exhaust bracket. Just tight working space.
    CygnusX191 likes this.
  5. Jan 1, 2020 at 10:06 AM
    #365
    TacoJeff19
    Jeff
    19' DCSB OR
    Finished installing and just went for a test drive. Clutch feels easier to predict, but the new feel is very different. It almost feels as if the pressure in the pedal changes with pressing.
    How does your pedal feel now? I had to bend the line quite a bit but I made it work.
    I think I got all the air out of the line. I just want to be sure the clutch is disengaging 100%
  6. Jan 1, 2020 at 1:52 PM
    #366
    Trident904
    Brian
    17 4Runner TRD OR
    My pedal felt nice and tight. If there’s any mush to it, you need to keep bleeding.
    CygnusX191, Norton and TeecoTaco like this.
  7. Jan 1, 2020 at 2:08 PM
    #367
    TacoJeff19
    Jeff
    19' DCSB OR
    I drove it today and I'd say it feels good for the most part. I have a hand pump vacuum bleeder but don't have access to it right now I might try that in the future
    CygnusX191 and TeecoTaco like this.
  8. Jan 1, 2020 at 3:04 PM
    #368
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Mine was same at first...figured was just tiny bit of air in it, after a few drives it sorted itself out. Give it some time/trips
  9. Jan 1, 2020 at 3:21 PM
    #369
    Trident904
    Brian
    17 4Runner TRD OR
    Don’t use a hand pump. Just don’t.
  10. Jan 1, 2020 at 6:33 PM
    #370
    TacoJeff19
    Jeff
    19' DCSB OR
    Do these trucks not respond well to one?
  11. Jan 1, 2020 at 6:41 PM
    #371
    Trident904
    Brian
    17 4Runner TRD OR
    Ask @Shellshock.
    Manual bleed it so you don’t run into problems.
  12. Jan 1, 2020 at 6:51 PM
    #372
    Shellshock
    Iowa
    I didn’t remove mine
    definitely still air in the line
    bad idea. Ask @tonered
    Bleed it and bleed it some more. Mine I thought I was done and did 2 more cycles and a bunch of air came out. Brake fluid is cheap, no reason to skimp on bleeding.
    tonered likes this.
  13. Jan 1, 2020 at 6:54 PM
    #373
    Shellshock
    Iowa
    this is the only bleeder I’ve heard of working successfully
    CygnusX191 and ajmogen[QUOTED] like this.
  14. Jan 1, 2020 at 6:57 PM
    #374
    Shellshock
    Iowa
    zero leaks with mine. 10,000+ miles and 6 months.
  15. Jan 1, 2020 at 7:10 PM
    #375
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    It really worked well. I completely drained the clutch reservoir during the install. Refilled using the reverse bleeder, first try, no fuss
    Shellshock[QUOTED] likes this.
  16. Jan 1, 2020 at 7:24 PM
    #376
    TacoJeff19
    Jeff
    19' DCSB OR
    I can't afford another vacuum bleeder so I'll have to try bleeding more tomorrow. I tried the method you sent me when I was bleeding the clutch this morning. Didn't get any air out after 2 hours of bleeding and a couple gravity bleeds. I bought a large bottle of Prestone DOT 3 today since I went through a whole small bottle the first time and I suppose I'll just use it up so it doesn't ruin sucking in air on the shelf. Any more tips? My tubing is 1/4" ID don't know if that's too big but it does fit over the bleeder and stretch a little but I wouldn't call it snug per-say. Think I should get some 1/8 tubing?
    I went for a good drive today and there is definitely more feel no problems engaging gears and the engagement point feels about halfway on the pedal.
    Thanks for all the feedback I appreciate it!
  17. Jan 1, 2020 at 7:28 PM
    #377
    Shellshock
    Iowa
    I assume you’ve checked to make sure you have no leaks?
  18. Jan 1, 2020 at 7:57 PM
    #378
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a no luck with vacuum bleeders on clutches. I have heard from a few folks that were successful, but many more who weren't.
    In the end, it is easy to do with a helper.
  19. Jan 1, 2020 at 8:24 PM
    #379
    TacoJeff19
    Jeff
    19' DCSB OR
    Yes I have, no leaks here
  20. Jan 2, 2020 at 12:04 PM
    #380
    TacoJeff19
    Jeff
    19' DCSB OR
    Just spent 30 mins bleeding again and WOW I thought the pedal felt good before, it feels great now!
    Eager to drive it!
