Accumulator Delete Kit - SOLD OUT - No More Kits
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Trident904, Dec 20, 2018.
  1. Mar 7, 2019 at 11:02 AM
    #161
    Trident904
    Trident904 [OP] Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Depends on the demand. I have enough material to make 20 more and if the demand isn’t there when these are gone, I won’t make anymore until the demand is there.
    Jerneyman[QUOTED] likes this.
  2. Mar 7, 2019 at 11:03 AM
    #162
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Understand. I'll go ahead and take one. I'll shoot you a PM.
  3. Mar 10, 2019 at 5:51 PM
    #163
    Thehighesttree
    Thehighesttree Active Member
    Benjamin
    2018 Cement TRD OR Manual
    Just installed mine today. Was relatively easy and took me around 30mins to do the install. I didn’t have to bleed it either which was nice because I didn’t have someone around to push the pedal for me. Thanks @Trident904
    Trident904[OP] and doublethebass like this.
  4. Mar 10, 2019 at 6:04 PM
    #164
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    How’d you manage to do it without bleeding?
  5. Mar 10, 2019 at 6:26 PM
    #165
    Trident904
    Brian
    17 4Runner TRD OR
    Bleed it anyway.
    Norton, pinochle and doublethebass like this.
  6. Mar 27, 2019 at 10:36 AM
    #166
    g2dietzy
    g2dietzy New Member
    Garrett
    2017 Tacoma TRD Sport DCSB 4x4 6MT
    message sent, please add me to the list
    Trident904[OP] likes this.
  7. Mar 30, 2019 at 8:27 PM
    #167
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Anyone on the fence about doing this, go for it. This has made my truck so much more enjoyable. I have no idea why Toyota put that piece of crap on this transmission but good riddance. I suspect that the accumulator is terrible for synchros. Wish I’d done this sooner.
  8. Mar 31, 2019 at 11:15 AM
    #168
    jmahad01
    jmahad01 Well-Known Member
    My delete leaked no matter how tight it was. When I finally took it off I noticed the flare was not the same as the factory one but more importantly it was flared at a slight angle which would definitely cause a leak. Not happy.
  9. Mar 31, 2019 at 11:23 AM
    #169
    Rujack
    Did you let @Trident904 know?
  10. Mar 31, 2019 at 12:07 PM
    #170
    jmahad01
    I have not. I am just going to make my own at this point.
  11. Mar 31, 2019 at 12:31 PM
    #171
    Trident904
    Brian
    17 4Runner TRD OR
    The flares are the same as the factory one. There’s only one kind of double flare. If it leaked, it wasn’t installed correctly. I’ve built over 120 of these and only had a couple leak because they weren’t tightened enough.
    doublethebass likes this.
  12. Mar 31, 2019 at 1:23 PM
    #172
    jmahad01
    I installed the OEM accumulator back in with zero issues.
  13. Mar 31, 2019 at 2:28 PM
    #173
    Trident904
    Brian
    17 4Runner TRD OR
    The problem I found with the fittings is that when you think they’re tight, they’re not seated. I had the same issue on mine when I first did it and it took a couple of extra turns to get it seated right.
    Norton and doublethebass like this.
  14. Mar 31, 2019 at 4:45 PM
    #174
    jmahad01
    I understand. While I am not a body builder, I did tighten with everything I got. It still leaked and not cross threaded or anything. Again, I reinstalled the accumulator and tightened the same way with no issues.
  15. Mar 31, 2019 at 5:05 PM
    #175
    Trident904
    Brian
    17 4Runner TRD OR
    That was the issue I had the first time. There is a sleeve in the return cylinder that once tightened enough will flatten 2 threads and then you’ll know it’s seated.
  16. Mar 31, 2019 at 5:13 PM
    #176
    Rujack
    Just having a good time man. Sorry you had trouble with yours. You just came in kinda gruff.
  17. Mar 31, 2019 at 5:32 PM
    #177
    jmahad01
    Yep got to that point. Not a problem. I am going to try an alternative and if I cannot get that to work, then it is on me.
  18. Mar 31, 2019 at 5:34 PM
    #178
    jmahad01
    No worries. It was a frustrating experience as I was not in the most comfortable position getting that thing on and off.
  19. Mar 31, 2019 at 5:54 PM
    #179
    Trident904
    Brian
    17 4Runner TRD OR
    PM me if it doesn’t work.
  20. Apr 2, 2019 at 10:23 AM
    #180
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    How reliable are these kits? Do they increase/decrease pedal travel and depress effort? Does engagement point at pedal change compared to stock? Does this kit reliably and consistently engage/disengage clutch and fly wheel during shifts?
