accurate odo after tire swap?
Discussion in 'Wheels & Tires' started by bt08231, Jan 31, 2012.
  1. Jan 31, 2012 at 1:38 PM
    bt08231
    bt08231 [OP] Well-Known Member
    Baltimore, MD
    09 Magnetic Grey SR5
    Stock
    I posted about this a few months back and never really got any solid answers.....after swapping 245x75's for 265x75's i have to be travelling a farther distance then my odo is saying correct? When i calculate my mileage it has gotten bad, and i cant imagine a small step up in tire size has cause all this. Does anyone know by what percentage i should be multiplying my miles driven by to get an accurate odo reading?
  2. Jan 31, 2012 at 1:45 PM
    bpkrules
    bpkrules Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
    I have been thinking the same thing.
  3. Jan 31, 2012 at 1:47 PM
    bt08231
    Baltimore, MD
    Stock
    its gotta be slighly off, a larger tire will cover a larger distance...
  4. Jan 31, 2012 at 3:07 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  5. Feb 1, 2012 at 10:53 AM
    bt08231
    Baltimore, MD
    Stock
    hmm that's an interesting tool, does anyone know how to use this tool to answer my question though? come on i know someone has done this...
  6. Feb 1, 2012 at 11:04 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    if i'm thinking right, since your tire rotations are 3.7% off, you'd need to multiply your mileage by 1.037. not much, but it is a difference. the weight between sizes makes a difference too.
  7. Feb 1, 2012 at 11:09 AM
    bt08231
    Baltimore, MD
    Stock
    ok cool that's exactly what i was thinking....just wasn't positive...
  8. Feb 1, 2012 at 11:14 AM
    The_Hodge
    SC
    yeah...i'm thinking that's right b/c the difference from a 265/65/17 to a 285/70/17 is 6.6% and around what i was seeing on my ultragauge when i calibrated it at the time.
  9. Feb 1, 2012 at 11:23 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Interesting when before I got larger tires my gps always said I was going slower than my speedo did. when I changed to larger tires its they were dead on the same. so I just looked at it is now everything is pretty accurate. I know a lot of aupt makers are making there speedo's say you are going faster than you really are I've seen it on my ninja and on my honda vtx. and we are talking a big difference like 70 mph on the speedo is actually 65. Its like they are secretly trying to slow us down. I have also confirmed this on those radar boxes that tell you how fast you are going.
  10. Feb 1, 2012 at 11:26 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    yea 3% is not bad at all. Im running 35s and im off by 12%. Just make sure to calculate this when doing oil changes. when your odo says you have gone 2900 miles you have actually gone over 3000.
  11. Feb 1, 2012 at 11:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You're correct.
    The Discount Tire Direct tool is nice, but the TW calculator is better for this. Plug in your old size for the 'current tire size' then type in your new size and the difference is given to you in % form. For the OP's situation, the percentage should be given to you as 3.7% so take your mileage, multiply by 1.037 and that's the mileage you're actually driving.
    http://www.tacomaworld.com/forum/tirecalc.php
  12. Feb 1, 2012 at 11:30 AM
    The_Hodge
    SC
    correct...all of our speedo's fast. the larger tire (depending on size) fixes the speedo issue, but knocks the ODO out.
  13. Feb 1, 2012 at 11:35 AM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Most tire manufacturers publish revs/mile for their individual tires and sizes. I used these numbers because tires of the same size are not exactly the same size.
    Take the bigger number, divide by the smaller number, and multiply this value by your odo reading.
  14. Feb 1, 2012 at 11:38 AM
    bt08231
    Baltimore, MD
    Stock
    Awesome! thanks for all the prompt help, now i can breath a sigh of relief when i check my mileage lol.
  15. Feb 1, 2012 at 11:38 AM
    A_Ninja_Racer
    Tampa, FL
    Yeah but wouldn't you think that if your speedily was wrong your odometer would also be wrong.
  16. Feb 1, 2012 at 11:40 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    I dont know about the taco's but when I changed tire sizes on my Express Van (plumbing vehicle) chevy had to go into the computer to tell it that the tires were a different size so it would read the MPH and stuff correct..just a thought
  17. Feb 1, 2012 at 11:44 AM
    Dustyroades
    London, Ontario
    2019 TRD Sport
    It's not. The speedo is off from the factory but the odo is right.
  18. Feb 1, 2012 at 11:52 AM
    The_Hodge
    SC
    the difference is that there is an analog/digital conversion. both ODO and speedo do not get the exact feed straight into it.
    reset the trip on your GPS and ODO, drive any distance w/ the larger tires and the ODO will ready a lower mileage.
