Accutune UCA’s and 285 70 17’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TyRoosevelt, Sep 21, 2023.
  1. Sep 21, 2023 at 8:32 PM
    TyRoosevelt
    TyRoosevelt [OP] Well-Known Member
    Colorado Springs, CO
    2023 Tacoma TRD Offroad
    2.5 inch Dobinson Lift Accutune UCAs 285 70 17 Baja Boss Tires Method Wheels Meso Customs full blackout interior RSG Sliders Bakflip Revolver Tonneau
    Hello everyone,
    For those that are wanting to fit a 285/70/17 tire without a cmc or any modification to the inner fender with a slight lift, accutune’s uca’s are the way to go. I have 285 70 17 baja boss tires, 0 offset wheels with 4.75 backspacing and NO rub. I am a little over 2 inches in the front with my lift.
    I have read a lot of different threads about fitting bigger tires and almost all of them stated that a cmc was necessary. I would agree in almost all instances but accutune designed their uca to fit 33s without the chop.
    I didn’t want to cut but I was planning on it just in case. I then decided to try out their uca’s and initially I was skeptical that the arms would make that much of a difference. It rubbed really bad after the install and before the alignment and now I have driven it for a week and put it to the test in all ways and I have no rub. In fact my tire is perfectly positioned in the wheel well with 3 degrees of caster.
    Hopefully this helps others who are wanting bigger tires, a more aggressive offset, and don’t want to cut with a relatively small lift.
    Just wanted to give another option to people on here.
    maronesjsk8 and CLOUDL1GHT like this.
  2. Mar 30, 2025 at 9:16 PM
    maronesjsk8
    maronesjsk8 I am here for help. I am dumb.
    Marone
    Communist California
    2023 Overpriced Tacoma
    Stuff I don't need.
    Anyone else have feedback using Accutune UCAs running a similar setup? I am curious how a -10 offset wheel will behave.
