Acted like a bad fuel pump.
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, Jul 7, 2019.
  1. Jul 7, 2019 at 9:57 AM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    My neighbor called to report his 98 3.4L 4x4 wouldn't start or stay running. Symptoms were no fuel pressure. He disconnected the fuel line from the tank to the filter. Put on a line to a bucket. Tried to start the truck and no fuel pressure. Damn. Must be a bad fuel pump.
    Next, he got into the bed and jumped up and down to shake the fuel tank. That shook whatever was obstructing the fuel flow lose and it started running again. If there is a sock on the fuel line, it must need some cleaning. We're going to hook up some compressed air to the fuel line to backflush the line into the tank then see how it goes.
  2. Jul 7, 2019 at 9:59 AM
    eon_blue
    Azusa, CA
    Had it been sitting for a long time? Sounds like maybe the tank needs to be emptied and cleaned if it's got a lot of crud in it
    CS_AR[OP] likes this.
  3. Jul 7, 2019 at 10:01 AM
    Glamisman
    Glamisman Well-Known Member
    it could be loose electrical too.
  4. Jul 7, 2019 at 10:36 AM
    CS_AR
    It has been sitting. Also, it was an oil field truck from TX that probably has a lot of crud in the tank. It should be removed and cleaned.
    eon_blue[QUOTED] likes this.
  5. Jul 7, 2019 at 10:36 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    1st gen pumps "usually" work or not. Brushes/commutators wear, connections fail and they quit.
    Irritating them with blows to the tank frequently can get them going but the writing is on the wall.
    The OE sock was more of a fine nylon screen. The service replacements are closer to deluxe quilted Downey. Asin aftermarket to the rescue again for a complete pump/sock/grommet/hose/clamp kit for less than $100.
    In any case if there was enough contaminates in the tank to "plug" the sock/pump I should think it's time to have a look inside.
    Keep in mind there are two check valves in the pump. One for "anti drain-back".
    Stolen pic
    ThunderOne and CS_AR[OP] like this.
  6. Jul 7, 2019 at 10:37 AM
    CS_AR
    Thanks for the info. I'll pass it along.
    Dirty Pool[QUOTED] likes this.
  7. Jul 7, 2019 at 10:40 AM
    CS_AR
    I think he's going to make an access door (like Chevy truck guys) in the bed so he can easily get to the fuel pump.
