Activating my rear locker and/or A Trac when not in Factory Low Range
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trainerted61, Mar 18, 2021.
  1. Mar 18, 2021 at 6:28 AM
    trainerted61
    trainerted61 [OP] Member
    2017 TRD DC SB 6 Spd
    TacoBox, Budbuilt, RPMFab, Relentless Fab, BP-51, DiamondBack
    So, I have a Marlin TacoBox. I have three low range choices: Factory only, Marlin only, and Factory plus Marlin. Factory low is around 2.7:1 reduction. Marlin is 4.7:1 reduction. I find Marlin low to be most useful. Problem: I have no access to my rear diff locker or A Trac when factory low is not being used.
    I am hoping someone on here can give me a clue about how I might tackle this issue.
  2. Mar 18, 2021 at 6:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Folks are working on a solution, but nothing yet.
    Search out @lapoltba 's and @BigWhiteTRD 's threads.
  3. Mar 18, 2021 at 7:05 AM
    trainerted61
  4. Mar 18, 2021 at 7:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Enjoy that marlin crawler.
    BigWhiteTRD likes this.
  5. Mar 18, 2021 at 8:28 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I think the thread below has a good bit of the data you need, but its going to need some effort to repurpose it to your particulars...
    4WD ECU Spoofer for FJ Transfer Case Install | Tacoma World
    The above thread I helped a guy get his rear locker, etc back after a FJ transmission swap, so for that specific swap he no longer had a transmission actuator nor ADD, so schematics are specific to that condition. I assume you are going to be a bit different.
    Alot depends on how you envisioning this working
    I suggest you take a quick read thru that thread, then come back to this thread and lets discuss what exactly you are shooting for. Think hard of what modes you want what goodies to be functional, as that is going to define how we spoof...
    (are you still using factory front diff ADD?)
    (do you want to use atrac while the transfer case is still in 2hi, or 4hi, etc....?)
    NOTE: any solution that I give you will be an electromechanical solution (relays, switches), not a microprocessor solution. Our ECUs are very sophisticated in monitoring for faults and fail-safes. Some of the work arounds i have found for an electromechanical solution require you to turn truck off to active/deactivate them, so truck ECU doesn't realize what we are doing. Its just the drawback because I can't do a reliable microprocessor solution)
    b3itz and tonered like this.
  6. Mar 18, 2021 at 8:51 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Ever thought about getting a CAN sniffer?
    BigWhiteTRD[QUOTED] and tonered like this.
  7. Mar 18, 2021 at 8:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's too close to Friday for that.
    :poking:
  8. Mar 18, 2021 at 8:55 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
  9. Mar 18, 2021 at 8:56 AM
    BigWhiteTRD
    Ted
    absolutely, as in 'it would be interesting if I could'
    In terms of my personal skill-set, it would WAYYYY too many man-hours before I felt I could make something like that semi-reliable. Too many other hobbies that I am neglecting as it is.
    splitbolt[QUOTED] likes this.
  10. Mar 18, 2021 at 3:04 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I have considered it, and even bought a spare 4x4 ecu to disassemble and mess with. I just haven't had a chance. I was thinking it may be possible to do a man in the middle type "attack" jus the way (I assume) the speedo recalibration modules work.
    BigWhiteTRD[QUOTED] likes this.
