Acts like it has a 4500rpm rev limiter
Discussion in '1st Gen. Tacomas (1995-2004)' started by dcm1978, Feb 18, 2023.
  1. Feb 19, 2023 at 11:06 AM
    dcm1978
    dcm1978 [OP] Member
    Don
    95 Tacoma SR5
    So, you never solved your cut out problem? The ImportDirect sensor I have is still a suspect.
  2. Feb 19, 2023 at 11:42 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What ignition coils are you using?
  3. Feb 19, 2023 at 12:09 PM
    dcm1978
    dcm1978 [OP] Member
    Don
    95 Tacoma SR5
    I think they are OE - never been replaced. Toyota/Denso
  4. Feb 19, 2023 at 12:27 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe slap some new MSD ignition coils onto it
  5. Feb 19, 2023 at 12:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Coils are plug wires are relatively new. Less than 50K on them. They are OEM.
    Ah, no.
  6. Feb 20, 2023 at 8:48 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I hear you, it is a concern. I bought mine with a dirty MAF and it was similar.
  7. Feb 20, 2023 at 9:31 AM
    dcm1978
    dcm1978 [OP] Member
    Don
    95 Tacoma SR5
    I'm waiting on the Toyota/Denso parts I ordered from Rock auto yesterday. Plugs, wires/boots, coil packs and a Denso crank sensor. I will clean the MAF today.
    See if that makes a difference. If not, then I will change one thing at a time, so I will know who the culprit is. Hopefully, one, or all of these things in combination will fix this.
    Thanks
  8. Feb 20, 2023 at 1:57 PM
    dcm1978
    dcm1978 [OP] Member
    Don
    95 Tacoma SR5
    For anyone interested: I cleaned the MAF and throttle body today. It may run a little better, but cutout problem is still there. Waiting on other parts to install.
  9. Jul 11, 2023 at 10:09 PM
    Cory_C
    Cory_C New Member
    cory
    96 Tacoma
    Did you resolve the issue? Currently having the same problem with mine.
  10. May 27, 2025 at 4:44 PM
    HolyD
    HolyD New Member
    David
    '98 Gold Tacoma 4wd TRD
    Mines a '98. Before I had to store it for a year or so, I had no problem hitting 6+. But once I pulled it outta storage, it has the same issue. I've tried a new crankshaft position sensor. No love there. I've cleaned my MAF. Again, no love. Any help would be soooo helpful.
