Actual Moderator with a Tacoma...But Definitely Not a Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jberry813, Oct 10, 2016.
  1. Dec 26, 2016 at 5:40 PM
    #661
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I saw someone else use a fj axle tube and fj case to get rid of the add
  2. Dec 26, 2016 at 6:01 PM
    #662
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
  3. Dec 26, 2016 at 6:06 PM
    #663
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    #2ndgenproblems
  4. Dec 26, 2016 at 6:08 PM
    #664
    cmack
    cmack Well-Known Member
    18 Burrito
    Fuck it. Time to sell it and buy a 1st gen or dare I say...3rd gen
    AaronArf and nfs257 like this.
  5. Dec 26, 2016 at 6:50 PM
    #665
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Hope that it's the pump, the rack in this Gen is a freaken PITA to remove and replace and it can suck a big one.
    The symptoms I'm having now are the same as they were with the OG rack. Very little power steering/heavy steering wheel and lots o whining at low speeds especially let's say when pulling into a parking spot. Loose sloppy play that suggests worn out TRE's or Uni-Balls that also would suggest bump steer at low speeds while on the trail. It's just the worn rack that can be visually verified when the wheels are off the ground and moving the wheels left to right, right to left. There's also a nice leak at the main seal on the driver side, and that's where all the play and slop can be seen.
    @blackhawke88 attributed a lot of front end issues he was having to everything but his rack. He replaced it right before our recent Death Valley trip and is saying all the issues are gone.
    Crom and nfs257 like this.
  6. Dec 26, 2016 at 9:38 PM
    #666
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    My rack went out today ...fuck out life
    Great fucken day
  7. Dec 26, 2016 at 10:29 PM
    #667
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Did you check the drop bracket ?
  8. Dec 26, 2016 at 10:42 PM
    #668
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    get crafty and make the shift fork actuate with a push pull cable. someone on here did it.
  9. Dec 26, 2016 at 10:58 PM
    #669
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I genuinely hate you. Muah
  10. Dec 26, 2016 at 11:11 PM
    #670
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Wow. Your day turned into a real shitshow. Sorry to hear that.
    jberry813[OP] likes this.
  11. Dec 27, 2016 at 9:42 AM
    #671
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    got more pics of the install? were did you mount the base? that one has a base unit and a detached face right? I have been looking at different options for the truck. What antenna did you run?
    Bentrodder likes this.
  12. Dec 27, 2016 at 1:13 PM
    #672
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No more pix. The base unit is mounted to the floor under the driver's seat. The unit does have a detachable face you can use for remote mounting. I drilled one small hole for the cable in the useless cubby hole and attached the face to the cubby with double sided 3m tape.
    As for the antenna, it's a Diamond MR77. Magnetic base, dual band 2m/70cm
  13. Dec 28, 2016 at 5:56 PM
    #673
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    That sucks. I just replaced the rack on mine, it makes for a shitty day.
  14. Dec 28, 2016 at 8:25 PM
    #674
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Cant wait (insert sarcasm)
  15. Dec 28, 2016 at 8:37 PM
    #675
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    1st gen racks are easy.
    Anderson likes this.
  16. Dec 28, 2016 at 8:38 PM
    #676
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    As long as you remove the middle bolt from the top of the rack and not try to remove the welded nut from the bottom :anonymous:
  17. Dec 28, 2016 at 8:39 PM
    #677
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Hahahaha never considered that before, but you aren't wrong
    jberry813[QUOTED][OP] likes this.
  18. Dec 28, 2016 at 9:47 PM
    #678
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So that fucker is welded on
  19. Dec 28, 2016 at 10:01 PM
    #679
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Gotta get it from the top. Shallow socket
  20. Dec 28, 2016 at 10:10 PM
    #680
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks bro!
