Actual Moderator with a Tacoma...But Definitely Not a Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jberry813, Oct 10, 2016.
  1. Dec 28, 2016 at 10:13 PM
    #681
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    One of the rack bolts on the second gen is a real bitch too if it's the original rack, once you replace the rack you put that asshole bolt in from the bottom...much happier that way lol
  2. Dec 28, 2016 at 10:18 PM
    #682
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Did a swap on my buddies 06, and you're 100% right about it. That bolt went in from the bottom after the switch.
    Arcticelf and Basikbiker[QUOTED] like this.
  3. Dec 29, 2016 at 12:23 AM
    #683
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You cut that one flush with the nut before you pull it and it will clear as you wiggle the rack out...as far a wiggling the rack out I highly suggest burning some incense, chanting satanic mumbo jumbo, drinking heavily, looking at it upside down and wearing gloves with padded knuckles.
  4. Dec 29, 2016 at 12:24 AM
    #684
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    the gloves are for punching yourself in the forehead when you can't get it out...
    Fernando likes this.
  5. Dec 29, 2016 at 3:51 AM
    #685
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Once we had everything unhooked, moved out of the way, and that damned bolt cut in half getting the rack out wasn't too bad.
    We did remove the front frame supports, and disconnect all the soft lines up there though.
  6. Dec 29, 2016 at 6:41 AM
    #686
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I think on the fist gen the nut is welded on the bottom. Right jberry?
    Seems like this job is gonna be a real bitch. Might just have a mechanic do it on the side for cheap. I just want my truck up and running
  7. Dec 29, 2016 at 7:10 AM
    #687
    scocar
    scocar Patron of the Farts
    Ugh. Do not like.
  8. Dec 29, 2016 at 8:08 AM
    #688
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It's not hard at all on a 1st gen. Hardest part was getting it lined back up.
  9. Dec 29, 2016 at 8:42 AM
    #689
    cynicalrider
    cynicalrider #NFG
    Jersey
    My most difficult part was getting the steering shaft separated from the input shaft because of rust. Then I invested in an air chisel and it zipped right off.
    Arcticelf likes this.
  10. Dec 29, 2016 at 9:10 AM
    #690
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Taking notes......
  11. Dec 29, 2016 at 9:14 AM
    #691
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    New fishing boat... fucking priceless:
  12. Dec 29, 2016 at 9:21 AM
    #692
    taczilla
    Marc
    2016 RAM Rebel
    Did you try the old school way? Turn the switch to 2wd, then back up for bout 40 feet. Sometimes that frees it up.
  13. Dec 29, 2016 at 5:15 PM
    #693
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Replaced my rack in about an hour. Not too bad if you cut the bolt. Definitely not fun though and definitely not fun in 8 degree weather.
  14. Dec 30, 2016 at 10:37 AM
    #694
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Well verdict is in. My guess was correct, it was the pinion bearing. But it's so fucked that it actually welded itself to the pinion gear shaft. They are going to try to cut it off, but new r&p is a possibility as well. Balls
    Mademan925 likes this.
  15. Dec 30, 2016 at 10:39 AM
    #695
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    Blows!
  16. Dec 30, 2016 at 10:51 AM
    #696
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Bummer....
  17. Dec 30, 2016 at 10:58 AM
    #697
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Wow. What could have caused this?
  18. Dec 30, 2016 at 12:20 PM
    #698
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Did the bearing actually come apart? Or did it just seize and start turning in the housing?
  19. Dec 30, 2016 at 3:48 PM
    #699
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Holy shit!
  20. Dec 30, 2016 at 5:28 PM
    #700
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    pretty sure that the drop bracket caused that...or it needs an east coast mojo exorcism
