Actual Moderator with a Tacoma...But Definitely Not a Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jberry813, Oct 10, 2016.
  1. Feb 12, 2017 at 4:30 PM
    #941
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I was at 18 psi in DV.
    And yessir on the springs. I removed all the preload out of the passenger and just a couple threads of preload on driver to get rid of the taco lean. I honestly don't know how much lift I have. Problem when you buy vs build and don't have stock numbers to compare too. But lift/ride height is just a number. Tune your shit for performance, not aesthetics. The truck sets the ride height
    dakotasyota, Coot83, bski22 and 2 others like this.
  2. Feb 12, 2017 at 4:33 PM
    #942
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Yeah, I kept measurements before and after cutting for 35s so I know how much lift I've got and where. I'll run out the collars and go from there.
    bski22 likes this.
  3. Feb 12, 2017 at 4:35 PM
    #943
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    My battery is relocated to the bed. So you might have some more weight up front than me. But literally zero preload on the passenger side. I'm happy with my ride height and up/down travel.
    Gramps, bski22 and tetten[QUOTED] like this.
  4. Feb 12, 2017 at 8:41 PM
    #944
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Some post-new-spring pack un-shackle-flip facts.
    With my old setup (Dakar and shackle flip with xj shackles) I did some driveshaft measurements and I would have needed a 4* shim on my leaf pack to get the driveline angles in check. For the time being while I had the flip, I had a 1" carrier bearing drop to get 2 of the 3 u-joints in check, but that big of a drop was fucking with the u-joint off the x-fer case flange. So I always had driveshaft vibes.
    With the new spring pack and back to stock geometry hangers and shackles and no diff drop, I was only 1.3* off. Generally speaking you want the u-joints less than 1* off, otherwise you will end up with driveline vibrations at some speeds/loads.
    I'm super anal retentive and hate driveline vibrations so I went to work with the angle finder. With three stacked washers under the CB I was able to get the angles to 0.1* difference.
  5. Feb 12, 2017 at 8:47 PM
    #945
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    So I guess what I mean by that is
  6. Feb 12, 2017 at 8:51 PM
    #946
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    SnowroxKT, Holloman, Neutral and 11 others like this.
  7. Feb 12, 2017 at 8:57 PM
    #947
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  8. Feb 12, 2017 at 11:53 PM
    #948
    tetten
    Andy
    Socal
    Another question I remembered I wanted to ask you....
    During that test drive you took me on and you drove through that wash and the rear end bucked/catapulted....was that solely due to the shackle flip? Or would that have happened even with an inverted shackle?
  9. Feb 12, 2017 at 11:59 PM
    #949
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Did you already sell the dakars ?
    bski22 likes this.
  10. Feb 13, 2017 at 6:57 AM
    #950
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    That was a hard buck. The inverted setup probably made it more harsh. I don't really have any good dirt miles with the new setup yet to compare though.
    Yes
  11. Feb 13, 2017 at 7:29 PM
    #951
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Does the same damn thing every lifted second gen owner since 2005 has figured out and...IMG_0316.PNG.jpg
    P.S. If that was an HF digital angle finder it's only accurate to +\- 10 degrees ...
  12. Feb 13, 2017 at 7:36 PM
    #952
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's an AccuRemote and good to +/- 0.2 degrees fuck you very much.
    And believe it or not, there are tons of uneducated people with flips. I'm just trying to bring actual facts, numbers, measurements, and logic to clarity. Don't like it? Eat a dick and unsub.
  13. Feb 13, 2017 at 7:44 PM
    #953
    T-Rex266
    Elon
    Logic? Fine. This is the 2nd gen area, and not the 3rd gen area. Logic is accepted.
    Holloman, Justin, Drainbung and 6 others like this.
  14. Feb 13, 2017 at 7:48 PM
    #954
    Normantaco
    Normantaco Well-Known Member
    Pensacola, Fl
    16 4Runner SR5
    Double like.
    Keep up the good work.
    Coot83 and jberry813[QUOTED][OP] like this.
  15. Feb 13, 2017 at 8:10 PM
    #955
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I still have a shackle flip and have no issues.
    And sir I shall not eat a dick and will continue to sub to this shit storm cause it's entertainment! :D
    Holloman, bski22, Nickel and 6 others like this.
  16. Feb 13, 2017 at 8:13 PM
    #956
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ok ok.
    So out of curiosity, what are your u-joint angles on the second and third u-joints (the one after the CB and the one on the pinion flange)?
  17. Feb 13, 2017 at 8:17 PM
    #957
    Gramps
    Gramps
    07 TRD DC 4x4
    I will check this week. I saw your post earlier on that and it has me curious but I haven't checked it yet. Honestly the only driveline vibe I have ever felt is when I floor it from a stop. I have always caulked that up to a little axle wrap from a standing start. But nothing at all through the power band like most feel.
  18. Feb 13, 2017 at 8:24 PM
    #958
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Some helpful info:
    https://youtu.be/f1m-Fh5kiRU
  19. Feb 13, 2017 at 8:39 PM
    #959
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You bet. But you have a first gen which has a double cardan CV joint on the driveshaft. Doesn't work quite the same way.
    Silver02Taco likes this.
  20. Feb 13, 2017 at 8:48 PM
    #960
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn! Eating dick shots fired!
    Haha.
