Actual Owners - Report on the Projector Headlights!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KB Voodoo, Sep 17, 2015.
  1. Sep 17, 2015 at 5:13 PM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    How much better are they than the previous reflector headlights? Tacoma owners have been longing for real headlights since day one, and now we finally have them.
    The projectors in my 4Runner were really dim (to me), so I put an HID kit from XenonDepot in them. What a world of difference!!
    This is the kit that I got: http://www.xenondepot.com/H11-HID-Kit-Xtreme-HID-p/xt-h11.htm
    They are a million times better than the Lifetime LED's that I put in my Tacoma's reflector housing.
    Can anyone confirm that the 2016 Tacoma uses an H11 low beam bulb?
    Apollo12 likes this.
  2. Sep 22, 2015 at 9:51 PM
    408Taco
    408Taco Member
    Wes
    Bay Area
    '16 DCSB TRD OR - SUPER WHITE
    yup I have a 2016 TRD OR and the headlight bulbs are H11, HID's are on the way.
  3. Sep 22, 2015 at 9:58 PM
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    I had some Lifetime LED's and finally sent them back for a refund, I then switched to VLEDS which were 100% better.
    I had a 2014 Rogue that had factory LED Headlights and they were sweet, a lot brighter and cleaner light than the HIDs I have had experience with.
    Will definately be looking at VLEDS to upgrade the projector halogens in the Tacoma, my brother has factory projector halogens in his truck and he is always bitching about them.
  4. Sep 23, 2015 at 4:40 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Were the factory bulbs sort of dim?
  5. Sep 23, 2015 at 7:34 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    - H11 on the low beams.
    - Projector beams on the new Tacoma are dim (tried them last night at a dealer)
    - Xenon Depot kits with Phillips bulbs are great. I have 3 cars with these kits in place for over 4 years and I have experienced zero issues.
  6. Sep 23, 2015 at 7:48 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Agreed. I have them in my 4Runner and they are awesome.
  7. Sep 23, 2015 at 8:29 AM
    usadaytrader
    usadaytrader Well-Known Member
    Are these aftermarket bulbs blinding? I hate being blinded by UFO lights on the freeway. They should get their eyes check instead of buying brighter bulbs.
    PoweredBySoy and styk like this.
  8. Sep 23, 2015 at 8:35 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    HID bulbs in projector housings aren't an issue. It's when people put them in reflector housings that they become blinding.
    Castle 4, numbah57, Large and 2 others like this.
  9. Sep 23, 2015 at 8:35 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I'll see if I can get Toytec to do some comparisons from low to high beam..
  10. Sep 23, 2015 at 8:39 AM
    usadaytrader
    Gotcha
  11. Sep 23, 2015 at 9:05 AM
    radchris88
    radchris88 Well-Known Member
    Christian
    NY
    2016 Tacoma TRD Off-Road MGM DCLB
    Yeah if you are blinded, you can tell they either didn't know what they were doing or cheaped out. Ricey shit.
    numbah57 likes this.
  12. Sep 23, 2015 at 9:25 AM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    What bulb size for the fogs in the 2016 TRD OR/SPORT?
  13. Sep 23, 2015 at 12:13 PM
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    Is it hard to install this kit? You have to rerun the harness? Is it super tight in the 2016? I had Xenon lights on my last car and there is no going back... I can't live like that!
  14. Sep 23, 2015 at 12:16 PM
    radchris88
    Christian
    NY
    https://www.tacomaworld.com/threads...ked-up-2016-silver-double-cab-offroad.391047/
    Check out this post. I have only upgraded one car so far to HID lights and love every second of it but I also did a stage 3 morimoto bi-xenon upgrade. I had to cook my lights in an oven and use a dremel to cut the back of my reflectors so there is no going back for me either. I don't regret it for a second and probably will do it for this truck as well. Not sure if will be able to afford $400 headlights again though. May be looking for alternatives.
  15. Sep 23, 2015 at 12:28 PM
    sundogbrew
    Joe
    Thanks for the info. I am sure someone will do it before me as mine still isn't built. I think it's funny that you took off some panels to sort of look around. Your truck looks great. Great write up in that thread!
  16. Sep 23, 2015 at 12:35 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The Xenondepot kits are really nice. Installation is straightforward. Set aside 90 minutes and just go through it step by step.
    On the Tacoma, you might have to move the windshield washer fluid tank and the battery. Both of these things are super easy to move. All you need is a 10mm socket and an extension.
    The difference in light output is well worth it.
    You can get 4300K, but I got 5000K for a true white light. Anything higher than 5000K gets you a one way ticket to Riceville.
    ratcityrain, numbah57 and radchris88 like this.
  17. Sep 23, 2015 at 3:08 PM
    radchris88
    Christian
    NY
    I didn't write this up, still waiting for my truck, but I have been following it. I figured it would answer some of your questions better than I could.
  18. Sep 25, 2015 at 1:22 AM
    KalihiforniaTaco
    KalihiforniaTaco Well-Known Member
    Honolulu, HI
    '16 Limited Tacoma
    Please post a DIY if you can; can't wait to see how they look!
  19. Sep 25, 2015 at 3:44 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    If I do plan on getting a 3rd gen, I'll definitely swap out the oem projectors for a tuned rx350 :drool:
  20. Sep 25, 2015 at 8:44 PM
    Soeperman
    Soeperman Well-Known Member
    2016 MGM DCLB TRD Sport
    knhorn likes this.
