Actual tire sizes
Discussion in 'Wheels & Tires' started by CorrosiveTendency, Nov 5, 2011.
  1. Nov 5, 2011 at 7:10 AM
    CorrosiveTendency
    CorrosiveTendency [OP] When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    What would the actual height of a 285/75/16 BFG AT be? Also, a 275/70. We should work on a list of the actual height of a tire, not just what it is sold as. I understand the BFG's are a tad under-sized...?
    Thinking about going to a 275 from my current 285's, I would lose about 1 1/4", by the calculator, but I am curious how the tire actually measures up.
  2. Nov 5, 2011 at 8:27 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    He wants the actual size measured with a tape on your truck.
    My BFG AT 285/75/17 sold as 33s
    Calculator says they are 33.8
    Measure 32.4 on my truck
    The general rule of thumb is you lose about a 1/2 inch once the tires are mounted and truck weight is upon them. I didn't measure them without being on the truck so I can't give you that number.
  3. Nov 6, 2011 at 6:30 AM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    For future referance, I'm not talking about the conversion or sizes as said by manufacturer. I am talking about ACTUAL size, the size of the tire measured by someone in the real-user world, not a company engineer. I've been all over this site, so I am fully aware of the "mods and tutorials" and the tires conversion. Thanks ...
  4. Nov 6, 2011 at 6:42 AM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Thank you. I know a 33" or 285 is not a full 33". Some brands run bigger than others ie: swampers seem to be on the bigger end, BFG and others seem to be under the stated sizes.
  5. Nov 6, 2011 at 6:43 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  6. Nov 6, 2011 at 6:48 AM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I'm chill. In my first post, I said "by the calculator". But whatever. It's all good.
  7. Nov 6, 2011 at 9:46 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    differs from tire to tire
    ive seen the same listed size vary close to an inch from different manufactures
  8. Nov 6, 2011 at 9:51 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I always wonder.. why do people refer to sizes shortened to just the width? a 285 could be a 24 inch tire depending on the aspect ratio and rim size.
    :sandwich:
  9. Nov 7, 2011 at 1:21 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    You make a good point. Got another sammich?
  10. Nov 7, 2011 at 3:06 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I believe its because they don't fully understand how it is figured out.
  11. Nov 8, 2011 at 3:44 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Quite possibly. I never really cared to get all up in that number junk. I like the simple 33x12.5x16 numbers
    Think you can explain it to us simpletons?
  12. Nov 8, 2011 at 3:45 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Play that violin boy!
  13. Nov 8, 2011 at 3:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    http://www.tirerack.com/tires/tires...pecs&PID=1921853&SID=two1169718&AID=10398365&
    285/75-R16 is listed as having 634 revs/mile
    1 mile = 63,360 inches
    So 63,360 / 634 / 2 / pi = 15.9" rolling radius
    The tire is listed as having a free diameter of 32.8", so 32.8/2 + 15.9 = 32.3".
    The tire would be 32.3" tall on the ground, presumably at the max load rating of 3305 lb at 65 psi max inflation pressure.
    The rule of thumb of manufacturer's advertised dia. minus half inch is close enough.
  14. Nov 8, 2011 at 4:26 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Oh geeze you had to go ahead and post something that's going to make me think. Good GAWD.
  15. Nov 8, 2011 at 4:31 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    No no! let the OP use a measurement taken by one guy on the ground running 30psi, and compare to another measurement by another member who runs 42psi and measures with the truck jacked up! :p
    Dude, really, the manufacturers specs are as likely a basis for comparison as you're going to find. While the numbers may not be completely "real world" they're going to be pretty darn good for comparison from one tire to another from the same manufacturer.
  16. Nov 8, 2011 at 4:34 PM
    KenLyns
    Belly of the Beast
    :laugh: Just look up the tire's free diameter on Tire Rack and subtract half an inch. Close enough for all intents and purposes.
    Keep in mind the tire diameter will decrease slightly with tread wear.
  17. Nov 8, 2011 at 6:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    285/70/R17
    285- The tires width in Millimeters
    70- Aspect Ratio 70% of the tires width in this case
    R- For Radial Construction (I always thought it meant Rim)
    17- Code for rim the tire fits on
    You will usually have an additional 2 numbers and a letter.
    The 2 numbers stand for what load the wheels can handle
    The letter is the speed rating for this tire
    Here are the 2 numbers and what they stand for
    The letters
    Q — Up to 100mph
    S— Up to 112mph
    T— Up to 118mph
    H— Up to 130mph
    V— Up to 149mph
    Z — 149mph and over
    W — Up to 168mph
    The fact that the middle number is a percentage is what causes the confusion.
  18. Nov 8, 2011 at 6:43 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Read on page 1 he asked for me to explain how to read the numbers. Thanks for playing
    I got it for you.
  19. Nov 8, 2011 at 6:49 PM
    99PreRunner.
    99PreRunner. ^ I no longer have a Tacoma
    Alex
    Mobile, AL
    2008 GMC 3500 Duramax 4x4 - CCLB
    a :sandwich:
  20. Nov 9, 2011 at 5:35 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Another sammich! where is mine dammit! As for the mumbo-jumbo about a 285 and rotations per mile and inches in a mile and 32.8 divided by the distance from my coffee table to the bathroom sink plus the square root of the speed of light minus the distortion caused by Earth's rotation and gravity plus the weight of a sweated prostitute....... thanks for the break down.
