Actuator wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZomBaja, Jan 23, 2016.
  1. Jan 23, 2016 at 8:36 PM
    ZomBaja
    ZomBaja [OP] Well-Known Member
    Dustin
    Central MS
    2002 Doublecab TRD Prerunner
    This is the connector coming off of the actuator on my transfer case.
    Can anyone identify the pins?
    I couldn't find a wiring diagram anywhere
  2. Jan 24, 2016 at 4:54 AM
    gearcruncher
    Canadain bumper technician
  3. Jan 24, 2016 at 9:30 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This might also help. Its a page from a my 1999 factory manual:
    Note the "2x4 select motor" in the diagram. That should be your connector.
  4. Jan 24, 2016 at 1:39 PM
    ZomBaja
    Dustin
    Central MS
    Damn it. None of those match the wires I have coming off the back of my connector.
    This t case came out of a 96 4Runner.
    Thought it should be the same though?
  5. Jan 25, 2016 at 3:40 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Umm, you guys disappoint me..... that plug is for:
    ZomBaja[OP] likes this.
  6. Jan 25, 2016 at 8:55 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The colors changed a bit over the years but the function is the same.
  7. Jan 26, 2016 at 7:39 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    I sent you the wiring diagram for the pins. Top two are for the motor, you switch polarity to spin motor forward and backwards using a DPDT switch. Lower left is 2wd indicator, lower middle is 4wd indicator, lower right is ground for the indicator pins. As far as indicator for 2/4wd I wired mine up to lights since I went prerunner to 4wd. The 2wd / 4wd lights are wired to the relay power (87) and the TC closes the circuit depending on if the TC is 2 or 4 wd, thus the light illuminates.
  8. Sep 28, 2024 at 2:47 PM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Hey, I need one for my 2003 Tacoma prerunner TRD 2wd 3.4L V6
