Acute Vibration Started at 22K mi - RESOLVED ? HOPE SO
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hugebass, May 3, 2016.
  1. May 11, 2016 at 4:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Let us know.
  2. May 11, 2016 at 4:15 PM
    hugebass
    hugebass [OP] Well-Known Member
    Reed
    Phoenix
    Off-Road
    UPDATE: Lift shop called today. Says they ran tests, vibration is obvious but can only point to drive-line. They said they lowered the carrier bearing and that didn't change anything. They believe the drive line is egg-rolling instead of true. They are sending it out today for re-balance. Said work will be done tomorrow and can re-test. Will post more when I get info.
  3. May 11, 2016 at 8:03 PM
    hydro19tfg
    hydro19tfg Making a Taco
    chris
    Southern Califas
    2012 Tacoma Prerunner
    maxtrac spindles 4" Procomp prorunner shocks F/R 1" block
  4. May 11, 2016 at 11:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What is egg-rolling? Never heard of that term before.
    I think they are full of poop.
    Keep us updated, really curious now. See if you can find out what egg-rolling is.
  5. May 12, 2016 at 7:40 AM
    Pigpen
    Dan
    Northwest Montana
    Think jumping rope...eliptical rotation instead of circular.
  6. May 12, 2016 at 8:58 AM
    hugebass
    Reed
    Phoenix
    Off-Road
    Yes, it wasn't some official term, they just used that as a way to describe what the drive line was doing. Imagine rolling an egg vs a true round ball. They believe this is causing the vibration. I've had my truck in 3 different places now. Sorta getting tired of nobody being able to figure it out so I'm hoping this is it. I also realize vibration issues are sometimes difficult to source. I've read so many posts about issues like this.
  7. May 12, 2016 at 10:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a term which I cannot remember. To a method which I do remember, but many tire shops don't have the tool to do the work.
    I used to read Off Road Adventures regularly. I really enjoyed the tech editorial at the back. They described a scenario where sometimes tires wear out of round. That there is the ability to trim off a few millimeters to get them back to a true round. Coincidentally,I was having a vibration issue with my 35" BFG mud terrains. Kept getting worse as the miles grew. Narrowed it down to the rear right wheel. Swapped it to the front, and holy shite. 4wheelparts didn't have that tool to trim the rubber. Bought two new tires to even them out. They had about half life on them and it was so bad that it would shake the bed at a certain rpm/speed.
    After that, when they started getting knobby, I'd do a little burnout and smooth them back up. :D
  8. May 13, 2016 at 4:40 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Out of balance? Or what is causing that defective universal joint or carrier bearing?
  9. May 13, 2016 at 7:48 AM
    Pigpen
    Dan
    Northwest Montana
    If the carrier bearing bushing (or the bearing itself) allows movement, it can do this because of the middle joint in the DS. If the shaft is out of balance it will do this and wreck both the u joint and CB
  10. May 13, 2016 at 4:13 PM
    TheDoctor9257
    TheDoctor9257 Well-Known Member
    Tyler
    Laguna Niguel
    Slice of Life (2008 Tacoma TRD Off Road)
    All Pro Front and Rear bumper with a warn vr12000 winch, King Mid Travel with front and rear adjusters, Rigid Pods, Viar Ultra On-Board Air, Siberian Express Train Horn
    Hello, I had one hell of a vibration under about 2200rpm and fixed it by pulling the air intake towards the center of the engine bay. The intake would slide out and into the wheel well and vibrate like nobody's business. My 2 cents and its easy to check
    sparkystaco likes this.
  11. May 13, 2016 at 8:28 PM
    hugebass
    Reed
    Phoenix
    Off-Road
    RESOLVED: Drive line out of balance. Sent out for re-balance. Carrier bearing required minor adjustment. Truck is as good as new! Love having my taco back!
  12. May 14, 2016 at 5:46 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Was it installed crooked? My 2015 was and it caused premature failure at 8k which took the rear end with it
  13. May 14, 2016 at 8:34 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The biggest question is How did it get out of balance?.
    IronPeak and Torspd like this.
  14. May 14, 2016 at 10:09 PM
    hugebass
    Reed
    Phoenix
    Off-Road
    Ya, I'd like to know. I'm not really sure. I purchased some jetski's a few months ago and have been taking trips to the lake 1-2 times a week. The entire rig is 3,500lbs. I also have 35's and geared 4:88 with a s/c. I'm not sure if that matters or not but it's the only thing I can think of that has changed.
    The out of balance issue went for about 1K miles before I starting chasing a fix around the city.
    Thoughts? ...and what kind of damage could an imbalanced driveline might have caused?
  15. May 15, 2016 at 4:33 AM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    It may not have effected anything. It could effect the transmission output shaft seal and or bearing and the same for the differential pinion shaft seal and bearing.
    Look for an oil leak in these areas and don't worry about it if you don't feel it or see a leak.
  16. May 15, 2016 at 8:39 AM
    #36
    hugebass
    Reed
    Phoenix
    Off-Road
    No leak; just feels like truck is now normal. It if happens again, at least I'll know what it is...or can rule that part out. Thanks for all the help with this guys!
  17. May 15, 2016 at 11:55 PM
    #37
    hugebass
    Reed
    Phoenix
    Off-Road
    Sheeeit! 2 days and vibration seems to have retuned. Bad drive line? Taking to bloody dealer tomorrow.
    1. Dealer blamed lift.
    2. Took to lift shop, they blamed dealer part, charged me $250 to balance driveline
    I'm about ready to rip out a can of whoopass …
  18. May 16, 2016 at 2:16 AM
    #38
    Jimmyh
    SC
    2012 Prerunner SR5
    Torspd likes this.
  19. May 16, 2016 at 3:34 AM
    #39
    Onlydad
    Onlydad Well-Known Member
    2014 Tacoma
    Stock
    IMHO it's a driveshaft issue. In my jeep I would remove the rear driveshaft completely and drive it around for a week or two FWD only. If this resolves your issue you know where to look. It could be that the driveshaft is balanced but not sleveing smoothly.. Not sure if your driveshaft sleves or it uses a slip yolk at the transfer case??
    Just my thoughts.. Carry on..
  20. May 16, 2016 at 4:12 PM
    #40
    hugebass
    Reed
    Phoenix
    Off-Road
    Thanks guys. This is a long drawn out biznitch of a problem.
    Bought truck new from dealer. Lifted truck through dealer (subd to DSI/4wheelparts). Purchased 100K/8Yr warranty.
    With this particular issue: Dealer sends me to sub. Sub replaces UJoint, carrier bearing adjusted, drive line balanced...it was good for about a day. Problem came back day later. Today I went back to my dealer, and he tells me because 4WheelParts did the driveline work, it voids my Toyota Warranty (Drive Chain). I seriously went Trump on his ass. Dealer subs work, dealer sends me to sub for repair, repair work done, and dealer says its their fault and they have to cover. WTF, seriously??? I was lead down a path by my own dealer to void my warranty. That is absolute BS.
    After a long fight, the truck is being evaluated again by sub. Sub says will likely call tomorrow with diagnosis and cover repairs.
    Toyota dealer is standing by this stupid notion that if they don't do the work, my warranty is void. Is that true? If so, why the F would anyone purchase a warranty?
    I thought that if any shop does work and uses OEM parts, is qualified to do that work, customer has receipt of work, then warranty stands. No? (Magnuson-Moss Warranty Act)
