Adapter for newer 2020 Tacoma Camera/tailgate to work with 2016 with 4-pin harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iflushedmycarkey, Sep 9, 2020.
  1. Sep 9, 2020 at 3:17 PM
    iflushedmycarkey
    iflushedmycarkey [OP] New Member
    Hi everyone,
    So as others I'm sure have also experienced, I got my tailgate stolen from my 2016 Tacoma a year or so ago. I decided to buy a new one from a wholesaler out of state as I have a $1,200.00 deductible on my insurance (and I knew my rate would go up if I reported it to them) and they had like-new gates for $500.
    However upon getting it I found out that the wiring harness for it does not fit the one on my truck. I have a 4-pin style similar to the one pictured here:
    but the tailgate I received has the newer 8-pin harness similar to the one pictured here:
    Is there an adapter or some way to get these two different harnesses or am I basically SOL at this point? I've tried searching here and googling it but it's such a niche issue I couldn't find anything. I know going through insurance would have prevented this but my budget just wouldn't allow it.
    Anyway, any help would be massively appreciated.
    Thanks!
  2. Sep 9, 2020 at 4:49 PM
    caribe makaira
    Caribbean, Puerto Rico
    Purchase the missing connector and de-pin the one you have, don't cut. Insert remove pins into connector that matches the vehicle.
    Tape off the extra shield wire.
    skeletron, RyanDCLB, daveeasa and 3 others like this.
  3. Sep 9, 2020 at 5:00 PM
    caribe makaira
  4. Sep 9, 2020 at 5:40 PM
    iflushedmycarkey
    Wow this is incredibly helpful! Thank you very much!
    I'm no electrician but I've done some basic stuff like wiring up an aftermarket horn on an old motorcycle so hopefully this should be doable for me. Thanks again!
  5. Sep 9, 2020 at 5:58 PM
    caribe makaira
    No problem.
    The view of the wires on the pic is looking into the connector, not from behind. But you have the vehicle connector, use it to confirm the wire placement.
  6. Sep 9, 2020 at 6:07 PM
    caribe makaira
    I haven't seen the hole the connector runs through, but it must be larger than the other years. I see potential to use that 2020 connector for the tailgate lock and the camera.:stirthepot:
  7. Sep 9, 2020 at 6:45 PM
    caribe makaira
  8. Sep 9, 2020 at 10:50 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Having a single connector would be fantastic. The opening is already rectangular.
    The biggest hurdles are probably those silly plastic inserts which grip the loom and limit its diameter. The lock wires are lower gauge than camera so fitting all 6 into the small loom looked like a decent challenge. And if you already have two cables then not much benefit to combining into a single plug unless tailgate removal is a daily chore. Of course nobody forces anyone to use the plastic holder.
    OP if you somehow got a tailgate with a lock actuator then you might want to take the time to connect it. Do you have 6 or more wires feeding your plug or only 4?
  9. Sep 10, 2020 at 10:44 AM
    caribe makaira
  10. Oct 3, 2022 at 10:55 AM
    randyrataj
    randyrataj Member
    Randy
    2020 Tacoma
    Did you ever resolve this? If anyone is checking this. I recently had the same issue, tail gate was stolen...
    I now have a 2018 tailgate for my 2020 and can't plug in the backup camera. Would love to trade someone for their camera that is having this issue as well.
    I need a 2019+ camera
    I have a brand new 2016-2018 camera.
    The tailgate I purchased was a take off from a plumbing company, was wrapped and in storage legit brand new.
    DES2009 likes this.
  11. Oct 3, 2022 at 11:11 AM
    daveeasa
    David
    PNW
    It’s much more work to open the tailgate and replace a camera than de-pinning a connector.
  12. Oct 3, 2022 at 11:29 AM
    caribe makaira
    Would you post a picture of the connector on the '18 tailgate and the one on your 2020?
    Guess you can't, not enough posts for that. (Forum "Rules")
  13. Oct 3, 2022 at 11:59 AM
    daveeasa
    David
    PNW
    Oh, it’s TE 025? I can probably make an adapter for each way.
    Caribe, this guy?
  14. Oct 3, 2022 at 12:00 PM
    daveeasa
    David
    PNW
    Ah, 12790 is the one at the tailgate?
  15. Oct 3, 2022 at 12:01 PM
    caribe makaira
  16. Oct 3, 2022 at 12:02 PM
    caribe makaira
  17. Oct 3, 2022 at 12:04 PM
    daveeasa
    David
    PNW
    So if it’s 8P and 8S TE 025 I can definitely get some of those and make adapters. Should be straightforward I’d think. Just need someone to confirm.
  18. Oct 3, 2022 at 12:05 PM
    daveeasa
    David
    PNW
    So we’d do 4 pos male to 6 pos female to allow a new truck to take an old tailgate and 4 pos female to 6 pos male to allow an old truck to take a new tailgate. Yeah? Just a matter of getting the pin maps right.
  19. Oct 3, 2022 at 12:17 PM
    randyrataj
    randyrataj Member
    Randy
    2020 Tacoma
    I think I found a solution but not 100% sure yet.
    Wire Tail Gate No - Toyota (82182-04050) https://parts.toyotaofanaheim.com/oem-parts/toyota-wire-tail-gate-no-8218204050
    This wire and plug will fit into my harness a the body end for sure. What I now need to know if it will fit into the camera side. Looks like the camera is the same for all models using a 6pin plug
    2018 Camera part number 86790-04040
    2020 camera part number 867b0-04040
    Looks like the male pins and plug are identical.
    I really don't want to cut or splice if I don't have to.
  20. Oct 4, 2022 at 10:10 AM
    randyrataj
    randyrataj Member
    Randy
    2020 Tacoma
    While looking into the wiring options, I also was still looking for my tailgate on market place and got a phot of the one linked here. I noticed a few small spots that have been difficult to clean off (surfboard wax)
    I had the seller deliver it to me, I inserted the key in the lock and it turned! Dude knew he was F*Ck#d and bounced, leaving my tailgate with me.
