Adaptive cruise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BobVilla, May 13, 2025.
  1. May 13, 2025 at 8:03 AM
    BobVilla
    BobVilla [OP] Member
    Big Nasty
    Is there a way to adjust the input power that is used by adaptive cruise control when following a vehicle, then the automated braking applies, and then when I change lanes, the system resumes the set point but yesterday the system did that to mine but the rpm’s shot up to about 45k just to gain only 5-7 mph. Is this normal that the system gun the throttle to resume the set point?
    Also, is it normal with adaptive cruise control to use so much braking force when following, adjusting, and braking? In the same situation, I could have applied much less manual braking force to accomplish the same thing the automated system is doing. I have set longest distance to follow.
  2. May 13, 2025 at 8:09 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Normal.
    Also, don't let cruise make more than a 5 mph adjustment to your speed. Its not very talented at it. If its braking and gassing, that's a sign you shouldn't be on cruise.
    pdxTacoSR5, Chew, lastcall190 and 2 others like this.
  3. May 13, 2025 at 8:18 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    45k is rather excessive! Just busting your chops. The adaptive cruise is very wonky in most toyotas...but it is normal for the truck to try to resume speed as quickly as possible.
  4. May 13, 2025 at 8:55 AM
    gologit
    gologit Well-Known Member
    In the redwoods.
    2023 SR5 4x4 long bed
    Nothing major or fancy. Just stuff to make it work better for me. Running boards, seat covers, BakFlip
    Enter truck, start engine, turn off adaptive cruise. Is this a possibility?
    rtzx9r and soundman98 like this.
  5. May 13, 2025 at 8:56 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    When turning the cruise on, hold the button until the green cruise light comes on. Places you on regular standard cruise, not adaptive. problem solved. Not a fan of the adaptive cruise, and not a fan of the cruise logic, and auto braking, to maintain speed. The modern dynamic braking in cruise control is idiotic. Coasting down a hill, and the brakes (including your brake lights) come on. All the while, your fellow motorist behind you, wondering why you are braking. SMH. Ski
  6. May 13, 2025 at 8:58 AM
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    I gotta be honest, I had absolutely no clue how to do NON adaptive cruise in this vehicle (never had one with it until now). That is great to know, thanks.
    Ngneer and BabyBilly like this.
  7. May 13, 2025 at 9:07 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes and yes. Adaptive cruise tried to maintain a constant gap. A human normally applies less braking force but reduces the gap (which seems more natural because the safe follow distance shortens with lower speed). The engine doesn't really wake up until above 4k, so that can be expected as well. Fortunately the engine is designed to rev and is quite happy staying above 4k (which is in stark contrast with the 4.0L that sounds like it'll blow up above 3k).
    Chew and Ngneer like this.
  8. May 13, 2025 at 10:18 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    as mentioned, all normal. Like any cruise, it is set for convenience, not economy. So it will slow down and speed up to attempt to keep the set speed.
    I find the best results using the minimum following distance, and still I have to change lanes well before to avoid the braking and attempts to shoot back up to set speed. The screen in the center of the dash will show when it detects something in front of you before it brakes. I no longer have to look at that, as I have a feel for about what the distance is.
  9. May 13, 2025 at 10:22 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Adaptive sucks. As for overall shit cruise control you should try a first gen Tundra. This is light years better - the non-adaptive.
  10. May 13, 2025 at 10:43 AM
    airforceb2cc
    Don
    KCMO
    I have a 1st gen sequoia...same thing. It is amazing cruise!
