Add 12v to bed with starter battery protection?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Aug 11, 2025 at 12:30 AM.
  1. Aug 11, 2025 at 12:30 AM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    I am routing 10 gauge wire to my truck bed via the starter battery and will be connecting directly to blue sea outlet. It will be used to run my bed led lights (via cigarette plug) and occasionally charge my small power station. As I’m likely to forget to switch the blue sea outlet off, is there a way I can set this up to cut power automatically if my starter battery reaches a certain capacity? I want the 12v to be always on so that I can use my led lights when engine is off bit not if the battery won’t start my truck.
  2. Aug 11, 2025 at 4:02 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    If nothing is plugged in you won’t drain the battery. Note your battery is a 12v but if you check the output voltage it’s a bit higher. Battery output is rated in amp hours (starting power) if your concerned about battery life get a tandem battery and mount it in the engine compartment. Drain from there and recharge it automatically when the engine is running.
  3. Aug 11, 2025 at 4:57 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  4. Aug 11, 2025 at 7:17 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Trucks2019[OP] likes this.
  5. Aug 11, 2025 at 7:35 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I think you'd want an isolated DCDC inverter like the Orion from Victron. It has low voltage cutoff, a voltage detection to sense when the truck is running, variable output so you don't overheat your alternator. Can run your dc loads and charge the power station when the engine is on, then you can run the loads from the power station when the engine is off. This would also let you tie in a victron mppt to the system to use solar if you choose.
    The current limitations on the cigarette plugs is a ceiling to consider. 15a max safely. Different connectors will let you pull more amps safely (if fused properly).
    I just realized you said power station not auxiliary battery so you may not need an solar charge controller if it's built into the power station.
  6. Aug 11, 2025 at 7:43 AM
    Trucks2019
  7. Aug 11, 2025 at 8:40 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    RTFM Here
  8. Aug 11, 2025 at 8:46 AM
    RyanDCLB
    4/19 DCLBOR
    For the blue sea LVD, yes.
