Add-a-fuse popped while running off-road lights.
Discussion in 'Lighting' started by euroshowoff, Jun 25, 2015.
  1. Jun 25, 2015 at 12:41 PM
    euroshowoff
    euroshowoff [OP] Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    So I currently have two pairs of Hella driving lights, and a pair of ditch lights mounted running of an aux blue sea fuse block. Using OTTRAW V1DAG66B toggle switch. The switch's are drawing power from an add a fuse circuit that I tapped off the interior fuse panel located under the dash. The lights are working as expected, however driving home late one night I decided to run all the lights at once, ended up blowing the 20amp fuse from the add a fuse, which killed power to my lights. Any idea why the switches were pulling that much power just for the LEDs to be lit?
  2. Jun 25, 2015 at 12:53 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    You probably already did this, but check that the two fuses in the add a fuse are in the right spots? Also 20A fuse for switch illumination is overkill. I'm not familiar with otrattw switches cause I don't use any but maybe consider a smaller fuse? Hope you figure it out!
  3. Jun 25, 2015 at 1:10 PM
    euroshowoff
    Stafford, VA
    Thanks. I originally had a 10amp which I accidentally blew, and the only other size I had at the time was 20 and higher, so thats what I used and it still popped. Currently running a 25 and it hasn't popped, but then again i haven't ran the lights for long either.
  4. Jun 25, 2015 at 1:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you not using a relay? Seems a lot of juice to go thru a switch.
  5. Jun 25, 2015 at 1:57 PM
    euroshowoff
    Stafford, VA
    Yes, I am using 3 relays. One per pair of Hella lights, one for the ditch lights. Trigger from the two hella relays are piggybacked together and ran to one switch in the cabin. So essentially one switch is all 4 of my hella roof lights, and one switch is being used for my ditch lights.
  6. Jun 25, 2015 at 4:53 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    is it possible you have one of the relays wired wrong? one of them may be pulling juice from the switch instead of the battery.
    Not sure what your definition of the trigger being piggy backed together menas...
    please clairify.
    Power from the switches should only be going to pin 86 on the relays.
  7. Jun 25, 2015 at 7:57 PM
    euroshowoff
    Stafford, VA
    This was my original line of thinking. I plan on checking this tomorrow when I get some free time.
    The two relays that operate each pair of hella lights have one wire running to a toggle switch so that the one switch can operate all 4 lights. I believe pin 30 gets power from the main fuse block and 86 is running to the switch but I will double check.
  8. Jul 12, 2015 at 12:37 PM
    euroshowoff
    Stafford, VA
    Finally have time for an update. So I finally pulled a relay to confirm the pin output. The diagram that hella provided is slightly different from the relay I received. In other words I had two of the pins that needed to be swapped. Notes below. Lights are running off a 7.5a fuse without issue at the moment. Thanks everyone for your input
    Sandman614 likes this.
  9. Jul 13, 2015 at 12:44 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Yeah it does look like the power was being pulled through the switch.
  10. Jul 13, 2015 at 4:30 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Alright, good to hear you got it sorted out.
