Add a fuse question to power midland mxt275
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cows Have Claws, Jan 14, 2021.
  1. Jan 14, 2021 at 12:57 PM
    Cows Have Claws
    Cows Have Claws [OP] Well-Known Member
    Oregon
    2024 Tacoma Trailhunter 6ft
    I want to power a Midland MXT275. I'm going to velcro it to the underside of the dash and use an add a fuse to tap power. Which fuse should I tap into? I've got a TRD-Pro. I'd rather not go straight to the battery because its got way too many things attached to it right now and I've already got the add a fuse on hand.
    I believe I want to have continuous power so the radio can be powered when the truck is off.
  2. Jan 14, 2021 at 2:47 PM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    The fuse block under the driver's side dash, behind the hood release, should have 2 empty slots. One is hot always. (Can't remember which one) That will work for what you're doing.
