add a leaf and block HELP!
Discussion in 'Suspension' started by ComaTosin, May 15, 2009.
  1. May 15, 2009 at 1:54 PM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    hey guys and girls. I am installing the 3 leaf add a leaf pack from wheelers and i also have the 1" block. it is shaped like a wedge and i windered what way it faced. fat side to the rear or front?
    thanks
  2. May 15, 2009 at 1:59 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    that sounds like the axle shims, not a lifting block. SHims are meant to decrease the angle of your drive shaft. Fat end faces the rear of the truck
  3. May 15, 2009 at 2:25 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    Sounds like a shim but it 1" tall. I think it is a block and shim all in one. Fat part to the rear. Got it. Anyone else?
    Just making sure before I instal u bolts. Thanks!
  4. May 15, 2009 at 2:26 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if it is in fact a block/shim, then yes, fat end goes to the back of the truck
  5. May 15, 2009 at 2:45 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    cool. hope to have this buttoned up tonight. thanks guys
    edit - Got it finished and it looks sweet. perfect height. I will post some pics when I get back home on monday. what an improvement in ride quality! replaced my daystar 2" blocks and factory overlaod springs with the wheelers 3leaf aal pack and a 1" block!
    thanks again
