Add a leaf and overload leaf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hmbj14, Mar 14, 2023.
  1. Mar 14, 2023 at 9:00 PM
    hmbj14
    hmbj14 [OP] New Member
    Taco
    02 taco
    I’m Doing the icon 1.5” add a leaf do I remove the overload leaf or keep it in?!
  2. Mar 14, 2023 at 9:15 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Different AAL but I left the overload leaf out on my wheelers AAL (I think it was wheelers) and gained about 1.5”. I think they said it would be 2” with the overload left in.
    hmbj14[OP] and jackn7 like this.
  3. Mar 15, 2023 at 8:21 AM
    PlataTaco
    PlataTaco Well-Known Member
    Cole
    Western WI
    2015 Silver Sky DCSB Ltd
    If it's their progressive 3-leaf AAL kit I put the same one in mine and took out the factory overload, ended up with about 1.5" as they advertise. It's meant to be installed that way I'm pretty sure but if you leave in the factory overload you'd have probably 2" so about the same as the Wheelers kit gkomo mentioned.
    hmbj14[OP] and gkomo like this.
  4. Mar 19, 2023 at 11:13 AM
    hmbj14
    Taco
    02 taco
    Ended up leaving the overload leaf and I think it was the right call
  5. Mar 27, 2023 at 7:57 PM
    Tacodrew22
    Tacodrew22 Member
    Andrew
    2022 Tacoma Trd-off-road
    2 inch trd lift kit
    I have a 1/2” block in the rear and my truck sits 1/2” high in the rear currently with just my soft topper ,shovel, traction boards and air compressor in the bed. But, when I load with gear it sits lower. Just ordered the Icon AAL. I would like to sit closer to an 1” high in the rear. Should I remove the block and overload spring and just run the AAL?
  6. Mar 27, 2023 at 8:31 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Left mine in when I installed progressive 3 leaf AAL.
  7. Mar 27, 2023 at 8:33 PM
    Bishop84
    Bishop84 Well-Known Member
    The overload actually adds a slight lift due to its positioning.
    My last AAL on my truck I was too cheap to buy new longer u bolts, so I ditched it.
    Overloads rarely are needed until these springs are inverted. The AAL will help prevent that.
    Are you doing AAL to old springs? I'd recommend against it.
  8. Mar 28, 2023 at 11:43 AM
    Tacodrew22
    Tacodrew22 Member
    Andrew
    2 inch trd lift kit
    I’m adding the icon add a leaf to the stock Trd off-road springs. Truck has 12k miles on it and the most it ever tows is a small little Jon boat. Springs are fine I just want to get rid of the rear block and add a little height for when I’m loaded down for camping
  9. Mar 31, 2023 at 6:18 PM
    Tacodrew22
    Tacodrew22 Member
    Andrew
    2 inch trd lift kit
    Update. I got the AAL today and got it installed. I opted to keep the factory overload leaf and remove the rear block. I went from 1/2” rear high on flat ground to 1” high on flat ground. So far the truck is drive like a dream. I feel that it tightened up the rear end just enough to keep it composed over bumps with out causing it to jump all over the place.
    If you do choose to keep the overload leaf be aware that there will be another retainer piece you will need to cut off the front of the overload leaf. I used a mixture of an angle grinder to get most of it then cleaned it up with some thick metal Diablo blades in my sawzall. Pretty surprised the sawzall worked so well! Let me know if you have questions.
