Add a leaf diy difficulty
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rndsommer40, Feb 2, 2025.
  1. Feb 2, 2025 at 2:39 PM
    rndsommer40
    rndsommer40 [OP] Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    2022 TRDOR. Have a little squat in the rear and too much bounce with the added weight from cap and some tools. Put on the blue SUMO springs and I'm pretty much riding on top of them. Thinking of doing an add a leaf? Any suggestions? How hard is it to do by yourself to those that have done it?
  2. Feb 2, 2025 at 2:52 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    It's not hard to do. Clamps are necessary or a ball joint press. Do one side at a time
    rndsommer40[OP] likes this.
  3. Feb 2, 2025 at 3:03 PM
    SpeySquatch
    2016 TRD OR DCSB
    Or you could do airbags and cradles and have complete control of how much weight you can hold back there + articulation…about $400 give or take
    I run them and use a small hand bike pump. Works great for all situations
  4. Feb 2, 2025 at 3:16 PM
    rndsommer40
    Ralph
    2022 TRD OffRd DCSB
    I'm open to that. Wouldn't they replace the SUMOs i put on? How is the longevity of air bags?
  5. Feb 2, 2025 at 3:44 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Need good quality c-clamps. pay attention to axle walking off of the seat. Have deep sockets and hack saw
  6. Feb 2, 2025 at 4:34 PM
    auskip07
    Skip
    Atlanta, Ga
    At one point to seat the axle back on the leaf. I had to grab the drum and place my feet on the leaf pack pull and push. I did it as one person and I'm confident you could do it also.
  7. Feb 2, 2025 at 4:38 PM
    Vlady
    Issy, WA
    When I did the other side, I ratchet the axle to the front so it won't wall off.
  8. Feb 2, 2025 at 7:35 PM
    SpeySquatch
    2016 TRD OR DCSB
    it would replace the sumos. I live by the desert. 4 years so far, no issues. If you consider this, PM me. I have some small things that can make this setup quiet too
  9. Feb 3, 2025 at 3:28 AM
    rndsommer40
    Ralph
    2022 TRD OffRd DCSB
    I think I'm gonna go with the airbags. Will be a job for the spring. Have no garage to work in and it's way too cold to spend time under my truck. Live in NY. TY
    SpeySquatch[QUOTED] likes this.
  10. Feb 3, 2025 at 8:53 PM
    MAVEN4
    MAVEN4 Well-Known Member
    Shawn
    Michigan
    23 TRDOR MGM
    22 TRDOR Lunar Rock RIP
    I'm running the bags with cradles and they can be noisy. What are you using to keep them quiet?
  11. Feb 3, 2025 at 9:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    For constant load, use add-a-leaf instead of airbags.
    Do one side at a time. Loosen (but don't remove) the U-bolts on the other side. That'll give you the wiggle room the move the axle to line up with the new center pin.
    Two chineseium C-clamps can hold the leaf pack together with no issues while you remove the center pin.
    rndsommer40[QUOTED][OP] and Chew like this.
  12. Feb 4, 2025 at 9:22 AM
    SpeySquatch
    2016 TRD OR DCSB
    You asked the magic question :D
    Piece of cake…just cut a circle of yoga mat, cut drain holes in it for water and small rocks/dirt, and silicone glue it into the cradles. Noise gone
  13. Feb 4, 2025 at 10:23 AM
    BPKlein
    BPKlein Active Member
    2023 TRD OR Lunar Rock
    AAL isn’t too bad of a job with two people.
    you also might want to look at Road Active Suspension. I would do RAS before AAL if you want the extra load capability, but not the lift.
