Add A Leaf, how much more capacity?
Discussion in 'Suspension' started by ERdept, Jul 15, 2008.
  1. Jul 15, 2008 at 4:25 PM
    ERdept
    ERdept [OP] Well-Known Member
    Got the Toytec Add a leaf springs for the rear.
    Website of Toytec doesn't say, but they do say it add extra capacity.
    How much more capacity do these leaf lifts add?
  2. Jul 15, 2008 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    An AAL does not add to the manufactures capacity rating of the vehicle. :)
    r2pinter and ndoldman59 like this.
  3. Jul 15, 2008 at 11:44 PM
    ERdept
    Everything I've read, including Toytec themselves say the AAL add extra capacity.
  4. Jul 16, 2008 at 4:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Chris is right....
    Having the Toytec Add-a-leaf does not give you 'permission' to go beyond the manufacturer recommendations of vehicle towing or hauling capacities.
    Why? There are many reason why toyota sets those limits and the leaf springs is only one of them. The AXLE itself is another reason ... The axle is what carries everything that you haul or tow. Even though the leaf springs might be able to handle more - but the axle strength would be jeapardized if you go beyond the towing/hauling capabilities of the vehicle.
  5. Jul 17, 2008 at 8:47 PM
    ERdept
    My intention is only to answer a question. That question being how much more capacity does the add a leaf add.
    My research indicated that most sellers do definitely say that they do add capacity.
    In fact this is the email response from Toytec.........
    "They definitely do add carrying capacity but they are not rated per pounds or designed as an overload spring".
    My question, once more is how much do they add?
  6. Jul 18, 2008 at 4:06 AM
    Janster
    Jandy
    Lancaster, PA
    If Toytec is telling you *they definately do add carrying capacity*....And I'm not trying to sound rude - Call Toytec and ask them how much they'll add. If they're making claims to it - then they should know the answer.
    If they can't tell you - then nobody on this forum can answer you.
    The fact of the matter is - you shouldn't go beyond the towing / hauling / carrying capacity set by Toyota.
  7. Jul 18, 2008 at 4:55 AM
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    you're not replacing your axle so you won't get an increase in capacity
  8. Jul 18, 2008 at 5:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Vehicle capacity is determined by many things, not just an AAL. Frame, suspension, axel, tires, breaks, transmission, etc.. Simply changeing out one item, does not increase your trucks capacity. If Toytec is claiming that their AAL increases payload capacity, they are opening themselves up for trouble. Toyota (and all other auto makers) engineer their vehicles and give them the rating they have according to how they will perform with said weight being carried/towed. :)
  9. Jul 18, 2008 at 6:05 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Perhaps Toytec means that it will prevent sagging under load, not necessarily that its adding any capability.
  10. Jul 18, 2008 at 8:08 AM
    ERdept
    OK, thanks all for the answers.
  11. May 12, 2023 at 3:40 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    As a few have stated only the manufacturer can certify the capacity. Sometime time for a laugh check the capacity of a car on the door post. I've seen a few with a #785 capacity. That means 4 #200 people would put it over the limit of the car. If I were a cop it would be hilarious to know the capacity and pull the driver over and have them choose who they would have to force out. It's not a joke, think about it, in this sue happy society of you were involved in an accident and you knew that you could say that the driver of the other car was unable to stop the car in time to avoid the accident because they didn't follow manufacturers recommendations.
