ADD-A-LEAF keeps slipping out!!! HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KalamaKid, Mar 15, 2010.
  1. Mar 15, 2010 at 11:22 PM
    KalamaKid
    KalamaKid [OP] Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    So i installed an ADD-A-LEAF from toytec on my 08 4x4 AC. Its the 2in leaf without the TSB installed. I put the Ultimate lift kit on and have no other problems except from this leaf spring. For three weeks now every four or five days i need to loosen my U-bolts and centering pin and realign my add a leaf. I don't know why but it keeps slipping from one side to the other as you can see in these pics its about .35 of an inch to the side. Last night i reset it and aligned them again. I torqued everything down properly and after driving three miles to safeway it moved .1 of an inch again. WTF can i do? Toytec do you have a product for me??? Any help please. Heres the pics
  2. Mar 15, 2010 at 11:25 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    I had the same problem and noticed that one side was taller then the other so it looked like it was put on the wrong side so i switched them over and then it stopped slipping out and looked even so might you have to go down that way also
  3. Mar 15, 2010 at 11:33 PM
    KalamaKid
    I thought about that but just before i put them on i looked at both of them and they were the exact same... And i made sure too that they are put on in the wright direction as well...
  4. Mar 15, 2010 at 11:35 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Have you looked at the top of your tailgate to see if its pretty straight? Because mine kept coming off to the side like yours. I didnt meant i switch the aals from the right side and the left side. I meant like on my left side switched the aal around tighted the u bolts again and bam my problems were solved. You said you alrdy tried this tho?
  5. Mar 15, 2010 at 11:40 PM
    KalamaKid
    yeah i installed them just as the AAL instructions toytec says with the long way to the rear. So i'm kind of at a loss. I was thinking i messed this up too but after looking at them a few times and readjusting them over and over i'm 97.4% sure there on right lol:D
  6. Mar 15, 2010 at 11:47 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Oh man my bad then that i couldnt help out at all. Now all i can say is maybe 3rd times a charm haha jp hopefully another tw member can help you out
  7. Mar 16, 2010 at 12:16 AM
    vicstacoma
    vicstacoma Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
    yeah just double check, triple check everything... sometimes you might miss some things that you are sure you didn't miss. I would just disassemble everything and then assemble it all over again, but that's just me. It wouldn't take that long to do it anyways. I was thinking the long side was not facing to the rear and that could be causing your problem, but you said you are sure long way is facing to the rear.
  8. Mar 16, 2010 at 12:30 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Does that really even matter? I just got the Deaver 10 pack and there's a leaf that sticks out a little more than the rest, didn't really think much of it...
  9. Mar 16, 2010 at 12:35 AM
    KalamaKid
    thats a good question... does it matter. I don't know but it bugs the shit out of me. I don't want to be wheeling and have it slip out some how going over some crazy hump, leaving me stuck somewhere. I guess the U bolts would hold it in there sorta. But if it is to one side or the other wouldn't this effect how level my axle is in relation to the bed under normal driving?:confused:
  10. Mar 16, 2010 at 12:43 AM
    James3492
    James3492 Well-Known Member
    James
    EAST COUNTY
    Black-out Tail lights Painted Rims & Hood Scoop
    get some new bolts and tighten the living crap out of it but don't break it :)
  11. Mar 16, 2010 at 12:45 AM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
  12. Mar 16, 2010 at 12:47 AM
    James3492
    James
    EAST COUNTY
  13. Mar 16, 2010 at 12:53 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
  14. Mar 16, 2010 at 12:55 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Absolutely. I had a real flexy CJ5 back in the day and after a good day of wheeling my AALs would start to slide out sideways (almost into my tires!). I just put on 2 more clamps over the AAL ends on each leafpack and problem solved. Just like the clamps furthur up on your leafpack.
    Kinda weird yours are doing it 3miles into a neighborhood stroll tho...
  15. Mar 16, 2010 at 12:56 AM
    KalamaKid
    i might try that. I'll stop by "Checkers" tomorrow and see if they have anything.
  16. Mar 16, 2010 at 12:58 AM
    KalamaKid
    I have a rather interesting drive way. It allows for a lot of flexing of the leaf springs in a out :p
  17. Mar 17, 2010 at 2:54 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    The AAL on my passengers side slid out about 1/4 inch about 2 days after installing it. But it has not moved from that spot for the last 9 months, so I just left it alone.
