Add a Leaf or shackles with OME Dakar?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98tacoma3rz, Sep 7, 2015.
  1. Sep 7, 2015 at 5:11 AM
    98tacoma3rz
    98tacoma3rz [OP] Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Have OME Dakars and since have added a lot of weight. I installed all pro shackles that are 3/4" longer. My question is should I put the OME add a leaf in and remove the longer shackle? Was thinking of putting stock height shackle in. Is the extra weight going to stretch the springs without the add a leaf?
  2. Sep 7, 2015 at 9:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would highly recommend taking the Dakars out and buying a completely new set of leafs that will add more lift and is heavier-duty for the heavy loads.
    If you're carrying a lot of weight...an Add-a-leaf won't last long. They will eventually flatten out. Also - they can put excessive stress on your dakars too. Leaf springs have an 'arch' in them. Every leaf in a leaf pak has the same built arch so they all match. When you stick an Add-a-leaf in .....(with a completely different arch), it causes the other leafs to bend un-naturally (added stress). They function a whole lot better when all the arches are equal.
    But that's my lame explanation based on my experiences. ;)
  3. Sep 7, 2015 at 10:25 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Depends on how much weight you're carrying but I would go with the OME add a leaf. From what I have seen with guys using the add a leaf if helps out quite a bit with weight.
    Another good reason and something I wouldn't worry about is the OME add a leaf was made for the Dakar leaf pack. It will fit right in and blend with the rest of the pack.
  4. Sep 7, 2015 at 12:40 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    What Janster is saying is true of you were adding a leaf to something like a stock leaf pack. It's what happened to my stock leaf pack as well.
    The OME leaf pack is designed to go with the OME add a leaf, like ToyoTaco said.
  5. Sep 7, 2015 at 12:53 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Yes, that's what I've read. The dakar add a leaf is made for the dakar leaf pack. I have at least an extra 200 pounds. It's sitting where I want it because I have extended shackles. I want to know if the added weight will flatten the dakar over time. Should I remove the shackles and add the leaf? Thanks.
    I have a fiberglass cap, heavy duty bumper, swing out tire carrier and fuel cans.
  6. Sep 7, 2015 at 1:04 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    The longer shackles will wear the leaf springs out a little quicker (and you will be a little more prone to crack a leaf), so yeah, it will flatten the Dakars faster over time than an add-a-leaf would.
  7. Sep 7, 2015 at 1:26 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Ok thanks! That's what I thought.
  8. Sep 7, 2015 at 2:30 PM
    otis24
    Mark
    California
    I'm in the same boat...camper shell, drawer system, soon to be fire swing out. I'm about a year away from upgrading my suspension from mostly stock plus an add a leaf.
  9. Sep 7, 2015 at 2:48 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Definitely get a fresh, whole new set. Wheelers has their own and they also sell Dakars.
  10. Sep 7, 2015 at 6:01 PM
    otis24
    Mark
    California
    Oh yeah! That's the plan. I should have gone that route in the first place.
