Add a leaf question
Discussion in 'Suspension' started by single cab, Jun 1, 2015.
  1. Jun 1, 2015 at 6:46 PM
    single cab
    single cab [OP] Well-Known Member
    upstate ny
    2012 Single cab 4x4 mt
    I'm looking to get a add a leaf for more capacity and so I don't look like I'm doin a wheelie down the road with my 6x10 box trailer
    I have a regular cab and I've looked up and found some mixed results. Would the 3 pack progressive kits benefit me more then a single leaf? I'm looking to lift the front around 2 inches as well. Thanks
  2. Jun 1, 2015 at 6:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The 3 leaf progressive AALs will ride better when you're unloaded, which is the main difference between them and a single AAL. I have the Wheeler's 3 leaf and very happy with it, left my OEM overload spring in when I installed it and got 2" of rear lift. I recommend.
  3. Jun 1, 2015 at 6:48 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Yes it will also last longer than a single AAL
  4. Jun 1, 2015 at 7:05 PM
    single cab
    upstate ny
    That's what I was leaning towards but I've heard they can't handle weight as well for some reason. But most of the time the truck is unloaded.
  5. Jun 1, 2015 at 7:13 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    have you considered air bags?
  6. Jun 1, 2015 at 7:35 PM
    T4RFTMFW
    Not true in my case. I don't haul super heavy, otherwise I'd have air bags. But I can out 700 lbs in the bed and drive all day without problems. I have a pic with a load this size, or 750 lbs that I'll post for you to see.
    Was nowhere near the bump stops with this load, either.
  7. Jun 1, 2015 at 7:54 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    3 leaf AAL deal with heavier weight better than single. If you haul a lot get airbags
  8. Jun 2, 2015 at 5:01 AM
    single cab
    upstate ny
    Transporting tools is generally 500 pounds or so
  9. Jun 2, 2015 at 7:16 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    So adding
    Didn't need the picture again, but, how much did the setup "raise" your truck? I'm looking for a little stability but with occasional loads and towing without the need to use a ladder to get in the cab. :)
    Or, would it just be better to get the Bilstein 5100's all around?
    I know there are a bunch of answers but I don't plan on any airbag system.
  10. Jun 2, 2015 at 10:05 AM
    T4RFTMFW
    I have 5100s all around with front set at 1.75 and the 3 leaf in the rear. I get in just fine, but I'm 6'7". I'm still on 265s so it isn't a big increase in height. 285s would add more height, so keep that in mind.
    My fiancé is 5'6" or so and pregnant and she's able to get in the cab just fine, though she does occasionally complain.
  11. Jun 2, 2015 at 10:07 AM
    T4RFTMFW
    My mom is 5'3" and gets in fine as well, actually.
    I like the height of the tailgate but it might be a little tall for others. If you want I can take a measurement for you?
  12. Jun 2, 2015 at 3:45 PM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Sure, take a measurement. I'm 6'2" and don't have issues. I just don't want to "lift" the truck, but get a better ride and better hauling springs. The stock ride is fine, just when I tow my car and haul things it squats and bounces too much. If I'm only going to raise an inch, no big deal. Thanks
  13. Jun 2, 2015 at 3:46 PM
    T4RFTMFW
    FWIW, I got 2" with the OEM overload spring retained in the leaf pack, without it, it drops down to 1.5" of lift which maybe appeals more to you, it rides softer as well without the overload spring - at the cost of a slight reduction in hauling stiffness. I'll grab a measurement now. Standby.
  14. Jun 2, 2015 at 3:48 PM
    T4RFTMFW
    33" from road surface to top of my tailgate (when the tailgate is down).
  15. Jun 11, 2015 at 6:28 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Thanks. Measured mine at 32" stock. So, with the leaf pack AND overload, is the 33" what you got, or is that without the overload? If it's with the overload, it's perfect for me. One inch is not that big a deal. Thanks again.
  16. Jun 11, 2015 at 8:27 AM
    T4RFTMFW
    I got 2" of lift. But yes, I'm at 33".
    It is a 2" lift AAL. You would end up around 34" with it installed.
  17. Jun 13, 2015 at 6:53 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Great! To verify, 3 leaf AAL with stock Overload and 5100's all around (front to 1.75 or whatever I like) and the ride height may only go an inch or two at the most while keeping the truck "fairly level"? If so, that's what I'd like to achieve. Plus the ride quality will be enhanced (on my TRD 4x4). Thanks for the info. :)
