ADD-A-LEAF QUESTION
Discussion in '3rd Gen. Tacomas (2016-2023)' started by batong_23, Jun 6, 2018.
  1. Jun 6, 2018 at 11:14 AM
    batong_23
    batong_23 [OP] vincedprince
    SoCal
    2017 white toyota tacoma trd sport
  2. Jun 6, 2018 at 1:31 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    My AAL (Icon) came with new u-bolts. I never bothered to check if they were different (or longer) than the old ones.
    batong_23[OP] likes this.
  3. Jun 6, 2018 at 1:37 PM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    I don't think the stock u-bolts are long enough for an add-a-leaf AND an axle shim. As I recall, they didn't have a lot of excess length on mine.
  4. Jun 6, 2018 at 1:41 PM
    batong_23
    SoCal
    so did you have to change your ubolts? which ones do you have now? do you know what the measurements are?
  5. Jun 6, 2018 at 1:42 PM
    STexaslovestacos
    Sam
    2017 MT TRD OR
    I put on a wheeler's flip kit & superbumps when I put on my Dakars. Didn't measure them.
    batong_23[QUOTED][OP] likes this.
  6. Jun 6, 2018 at 1:45 PM
    Ram.95
    Ram.95 Well-Known Member
    2017 Black Tacoma TRD OR 4x4 Dallas Tx
    TRD PRO Bilstein Suspension HS Progressive AAL
  7. Jun 6, 2018 at 5:15 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    I can't speak for that add-a-leaf since I have no dealings with that company. I can say pretty confidently that they are not Deaver like the ones that we along with many other TW vendors sale. When using the Deaver single leaf add-a-leaf, longer u-bolts are not necessarily required. As long as the factory ones have not been modified and that the thread completely passes through the nut they should be long enough to accommodate the add-a-leaf. Some people do not like to re-torque a bolt so if you want we do have our HS U-bolts available that will work with the single aal.
    http://www.headstrongoffroad.com/store/p221/HeadStrong_U-bolts.html
    Dirty Harry and Ram.95 like this.
  8. Jun 6, 2018 at 9:39 PM
    batong_23
    SoCal
    Thanks! Another question, how thick is your single leaf add-a-leaf?
  9. Oct 23, 2020 at 4:30 AM
    mfalbojr
    mfalbojr Well-Known Member
    Kansas City, MO
    2024 TRD Sport Silver
  10. Oct 23, 2020 at 7:36 AM
    TacoBoutNothing
    TacoBoutNothing Well-Known Member
    2019 White TRD Pro
    I had Icon progressives installed, which I was "told" were manufactured by Deaver. They came with new bolts. The ride is great, but they started to sag a bit, which is throwing a must fix bro-lean problem at me. Other than a couple of camping trips, my bed is usually empty.
