Add a leaf trd pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 123tacopro, Sep 16, 2021.
  1. Sep 16, 2021 at 10:42 AM
    123tacopro
    123tacopro [OP] Member
    Kevin
    2021 lunar rock trd pro
    Bedrack spare on top
    Hi I am new here just bought a 2021 TRD pro Luna rock I added a bed rack with a spare tire on top I was wondering since I noticed a little bit of sag should I get An Add a leaf kit if so which kit would you recommend? about 200 pounds of constant weight and will be putting some extra Weight while going camping in the bed
  2. Sep 16, 2021 at 10:45 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    ToyTec worked well on mine and supports the added weight of my topper nicely. Does not ride harsh either.
    BOZOJUICE and Lphonzy09 like this.
  3. Sep 16, 2021 at 10:50 AM
    123tacopro
    Kevin
    Thanks I will look into that any other suggestions?
  4. Sep 16, 2021 at 10:58 AM
    ajackinthebox99
    ajackinthebox99 Noob
    AJ
    Cincinnati, OH
    2021 Premium TRD Sport
    Method 305NV 265/70R17
    I personally think add a leaf is only good if you are just wanting to lift, but since you are adding weight I would go with a Dakar leaf pack
    Tocamo and Taco_Coma like this.
  5. Sep 16, 2021 at 11:47 AM
    123tacopro
    Kevin
    Would it make my ride stiffer?
  6. Sep 16, 2021 at 12:40 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Yes.
  7. Sep 16, 2021 at 1:07 PM
    123tacopro
    Kevin
    Ok bummer thanks!
    I will have to find another option then i dont want to lose the pro suspension ride i just want to stop the sag when putting weight any suggestions?
  8. Sep 16, 2021 at 1:14 PM
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    I put an add a leaf kit on mine , the Icon AAL and Timbren bump stops with U bolt flip kit made a lot of difference and drives better when loaded.
    The leafs are the same on all models nothing different with the PRO. I would have replaced the whole leaf pack but since it was new the add a leaf was a more affordable and appropriate option.
  9. Sep 16, 2021 at 1:48 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    Mine is a TRD Sport so I cannot speak for the Pro but I like the ride I got better with the add a leaf than without. It stiffened the ride but in a good way. Not like a horse and buggy lol.
    BOZOJUICE likes this.
  10. Sep 16, 2021 at 1:49 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    It is only 200# he added. Not like he is carrying a slip tank around.
  11. Sep 16, 2021 at 1:53 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    If you just want to keep the rear from sagging when loaded without changing the feel of your suspension....air bags.
    Foster Imposter likes this.
  12. Sep 16, 2021 at 3:23 PM
    siderman
    siderman Well-Known Member
    Helwig helper springs. Keep it simple and inexpensive.get the 500# ones, meant as levelers.
  13. Sep 16, 2021 at 3:24 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Get an airbag!
  14. Sep 16, 2021 at 3:47 PM
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    another vote for airbags :cheers:
  15. Sep 16, 2021 at 4:58 PM
    123tacopro
    Kevin
    Thanks!! For all the info! Will look into icon AAL
  16. Sep 17, 2021 at 10:39 AM
    kderp
    kderp Well-Known Member
    Phila PA
    2021 Tacoma TRD Bro
    I just did the Icon AAL, I posted some thoughts in the Lunar Rock thread.
  17. Sep 18, 2021 at 1:37 PM
    123tacopro
    Kevin
    You like the ride?
  18. Sep 18, 2021 at 4:07 PM
    WiFiDoctor
    WiFiDoctor Well-Known Member
    2021 TRD Pro
    I have the exact same truck with the exact same problem. I purchased a set of add a leafs from wheelers off road- they specifically state 1.5” of lift
    I have not had a chance to install them yet - will update this post as soon as I get them in
  19. Sep 18, 2021 at 4:15 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I've read that the add a leaf flattens after a while, if you have weight in the rear. (Please don't quote me, that's just what I've heard).
  20. Sep 18, 2021 at 4:16 PM
    YMMPRO
    A little over two years on my with constant load of about 300lbs and no issues so far .
    Tocamo[QUOTED] likes this.
