Add a leaf vs. Dakar leaf pack
Discussion in 'Suspension' started by gomerpile1985, Feb 16, 2010.
  1. Feb 16, 2010 at 5:12 PM
    gomerpile1985
    gomerpile1985 [OP] Member
    COVINGTON, LA
    White SR5 6spd 4X4
    Secondary air filter removal, 3" complete O.M.E. set up with 885 coils, rear TSB + toytec add a leaf, TRD offroad wheels with 255/85/16 BFG KM2s
    About to pull the trigger on a 3" lift, definitely going with toytec adj. coilovers in the front just not sure about the rear. Trying to decide whether or not to just order the ultimate lift from toytec with add a leafs or spend a few extra bucks and get all new packs, probably the Dakar ($339.00/pair TRDparts4U.com) Just wondering if anyone got the ultimate lift and regret not getting new packs. Don't pull or haul anything crazy, really just interested in the new packs because you get 2.75" vs. 2" with the add a leafs. Wanna do it right the first time for once so money is actually not gonna be the deciding factor for once....:eek::eek::eek: Any thoughts or 2 cents worth would be greatly appreciated. By the way my name's Matt and I just joined, great site!! I have a 2010 SR5 4x4 6spd access cab. Thanks a ton.
  2. Feb 16, 2010 at 5:26 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    if moneys not holdin ya back then definitly go with the dakars man. i wish i woulda done it right the first time, its cheaper that way
  3. Feb 16, 2010 at 5:27 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    I ended up pulling the stock leaf pack and swapping it for a 1.5" leaf pack from All Pro. Been happy ever since; (the truck may appear to, but it has no "taco-lean" or "cali-lean")
    I would have gone Dakars, but witnessed myself how much they sag, and decided F THAT!
  4. Feb 16, 2010 at 5:28 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Welcome to TW. Your choice in front is a dandy. In the back, your needs/wants matter most. If you are looking for a a higher lift + load carrying boost in back, you may consider getting Toyota to do the rear leaf TSB for free then add a $75 leaf. That will put you right up n the same height range.
    Before you pull the trigger, may I suggest you do some research. Use the search button, click around in the suspension forum, and find out the pros and cons of each.
  5. Feb 16, 2010 at 5:31 PM
    kagmyster00
    kagmyster00 Well-Known Member
    Mark
    05AccessOffroad
    i would go with the dakar's if money isn't holding you back wish i could say the same :(
  6. Feb 16, 2010 at 5:34 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Hmmm.. just checked and you are right. They must have pulled the 1.5" from production. I was probably the only one that ordered it! HAHA
  7. Feb 16, 2010 at 5:39 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    5100s should be fine and extended brake lines if you go the 3" leafpack. The 1.5" leafpack you can get away with your stock lines... but I replaced mine anyway. And the 3" leafpacks were the same price anyway. 1.5" of difference isn't much. Youll be happy with the 3"
  8. Feb 16, 2010 at 7:27 PM
    gomerpile1985
    COVINGTON, LA
    White SR5 6spd 4X4
    The add a leaf that accompaines the tsb supposedly gives you an 1.5", on top of the 1" to 1 1/2" from the tsb and i guess you end up with 2.5 to 3". Same as the Dakar packs. So I guess that would be the cheaper route. Are the stock bily's they upgrade you to with the tsb long enough for all that? Or do you need 5100's?:confused: I guess you start splitting hairs with the heigth issue, and it all depends on what you haul to ultimately make the decision.
    WILDPEAK likes this.
  9. Feb 16, 2010 at 7:34 PM
    gomerpile1985
    COVINGTON, LA
    White SR5 6spd 4X4
    I'm wanting to run 255/85/16 so I wanna get it up there pretty good. I started a thread in the tires and wheels section trying to get input on this size on a 2nd generation. Haven't found anybody running em' on the 2nd's. Any response to it would be awesome.:D
  10. Feb 16, 2010 at 7:36 PM
    gomerpile1985
    COVINGTON, LA
    White SR5 6spd 4X4
    Are you saying the Dakar packs sagged?
  11. Feb 20, 2015 at 8:44 AM
    Jeremy421
    Jeremy421 Active Member
    02 tacoma limited v6
    What is tsb?
  12. Feb 20, 2015 at 8:53 AM
    Large
    Large Red
    Adding a leaf to an already saggy pack is like putting a band aid on it. Buy the dakars, you will be happy.
  13. Feb 20, 2015 at 8:58 AM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Dakars!!
  14. Feb 20, 2015 at 9:07 AM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    Technical Service Bulletin
  15. Feb 22, 2015 at 10:11 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I have an AAL on an old TSB leaf pack. They still sagged and rode horribly stiff (Toytec single leaf AAL).
    Couldn't handle the awful ride and put in Dakar's. Definitely no sag, hold my trailer weight great and ride awesome. Do it right and go Dakar's.
  16. Feb 22, 2015 at 10:21 AM
    eja12a
    eja12a Well-Known Member
    Ethan
    Tennessee
    2014 DCSB SR5 4x4
    OME Lift, LR UCAs
    i have the dakars and 255/85s on a second gen the dakars ride stiff, but i also dont have much weight in my bed.
    http://www.tacomaworld.com/forum/wheels-tires/155849-255-85-r16-owners-experience.html
    this thread has a lot of good info
  17. Feb 23, 2015 at 9:01 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Not even a little bit on mine, even with a 4 wheeler in the back and a trailer pulling another one.
