Add a leaf what to choose ?
Discussion in 'Suspension' started by Chrisjf66, May 22, 2013.
  1. May 22, 2013 at 4:41 AM
    Chrisjf66
    Chrisjf66 [OP] Member
    Ok so I was suppose to get my tacoma a week or two Ago but funds didnt allow that. I will be getting it by the end of the week and I'm going bilistein 5100 front and rear. But for rear idk which leaf to choose....
    Wheelers 3 leaf 1.5inch
    Toytec 1.5
    Or
    ICON 1.5?
    Also knowing this if in correct so maxed out bilistein 2.5 inches added in front and 1 from bilistein in back and 1.5 from leaf to make 2.5?
  2. May 22, 2013 at 4:57 AM
    Large
    Large Red
    You don't get lift with rear shocks, I'm not sure what you were trying to say there. As far as your AAL goes, the ICON progessive 3 leaf AAL has pretty good reviews and not as much squeaking.
  3. May 22, 2013 at 5:13 AM
    Chrisjf66
    Oh I could have swore the bilistein rear say 0-1.0" but ya I only hear great things about ICON stuff
  4. May 22, 2013 at 5:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They say that meaning that shock will work for a truck with 0-1" of rear lift.
    Out of those 3 choices, I'd go with either the Icon or Wheeler's 3-leaf AAL (they are very similar). If you want more lift, leave the overload leaf in place and you'll actually gain 2" of lift instead of the advertised 1.5". I have the Icon 3-leaf and have been very happy with it so far.
  5. May 22, 2013 at 5:22 AM
    Chrisjf66
    Ya I'm going to go with the ICON thanks very much! Now for tire decisions
    :confused:
  6. May 22, 2013 at 9:23 AM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    I am thinking of something very similar...
    5100s in front set at 1.75...Icon aal in rear for 1.5" lift there
    my main question...do I need to get new rear shocks? they don't add to lift it feels like I would be spending an additional $165 or so for no reason...lmk if/why i should get rear shocks, please.
    I plan to place 265/70/17 on my stock sport wheels
    looking forward to the lift!
  7. May 22, 2013 at 11:19 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What year and model is your truck? Short Bed, or Long Bed? Do you haul weight in the bed much?
  8. May 22, 2013 at 11:23 AM
    Pugga
    Massachusetts
    If you have the TRD Bilstein shocks and they're in good shape, you could probably get away with running them for a while. The reason for getting new shocks is additional or better dampening abilities. The AAL essentially gives you a stiffer and stronger leaf pack and the stock shocks simply aren't made to dampen the stiffer springs. Running too weak of a shock could result in a poor ride and a bouncy rear end.
  9. May 22, 2013 at 11:25 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Wheelers is the same as ICON but made in America :oldglory:
  10. May 22, 2013 at 11:36 AM
    Pugga
    Massachusetts
    The Wheeler's standard 3-leaf AAL is similar to the Icon one but they're not the same. Wheeler's also makes an HD version of the 3-leaf AAL.
  11. May 22, 2013 at 11:36 AM
    Monster Coma
    Corey
    Thats what I meant..
  12. May 22, 2013 at 11:38 AM
    Pugga
    Massachusetts
    I know, think of me as your translator :laugh:
  13. May 22, 2013 at 11:41 AM
    Monster Coma
    Corey
    :rolleyes::)
  14. May 22, 2013 at 11:44 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    How are they not the same. Isn't it all just a 3 leaf AAL produced by deaver? Pretty sure this is the case, but I've been wrong a time or two :D
  15. May 22, 2013 at 12:04 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    brand new Dbl cab Trd Sport short bed...I do not want a harsh ride...what do you think drop the extra $160 on rear 5100s or keep the stock TRD bilstiens?
    also is an ICON progressive 3 leaf aal for around $200 or just a standard 1.5" single aal for around $80 (from toytec or headstrong) going to give me a better ride?
    I will be running 265/70/17 P rated Rugged terrains on stock sport rims
    I dont haul anything or carry extra weight in the bed
  16. May 22, 2013 at 12:13 PM
    Pugga
    Massachusetts
    They're not both made by Deaver. Performance-wise, they will be very similar, they're competitively priced with one another but made by different spring companies. It's like comparing a Deaver leaf pack and an Alcan leaf pack built to the same specs. Also, Icon does not offer an HD version of their 3-leaf AAL like Wheeler's does.
    Personally, I think the 3 leaf AAL's ride better than the single AALs. I'm very happy with the way mine rides and others with the same setup seem to like the ride also.
    As far as the shocks, not sure what to tell you. You can try to run the stock shocks and see how they feel. If you like it, you saved yourself some money, if not, you'll end up buying new shocks to get the ride better controlled. You should know that running stock shocks with the AAL will wear out the shocks quicker so you will need to upgrade the shocks at some point regardless (might be a year or 2 out, depending on how you use your truck).
  17. May 22, 2013 at 12:18 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I had Wheeler's 3 leaf progressive AAL with the OL left in and it was perfect for me. It did, however, squeak a bit on one side whenever it was wet out . . . for some people that would be horrifically annoying, others don't care at all, or somewhere in between.
    But x2 on all the Icon or Wheeler's 3 leaf recommendations.
  18. May 22, 2013 at 12:18 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    X2
  19. May 22, 2013 at 12:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I greased in between each leaf, and also threw some along the contact point of the clamps and leaves, u bolts and leaves, and bushings.
    No racket for over a year
    Ymmv using different methods.
  20. May 22, 2013 at 12:23 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Ive seen the old tire tubes between each leaf done haha worked pretty good but I didn't want to take everything back apart and didn't mind the squeak.
