Add A Leaf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NihongoTaco, Aug 5, 2018.
  1. Aug 5, 2018 at 5:12 PM
    NihongoTaco
    NihongoTaco [OP] Well-Known Member
    Cyrus
    Stock 2011 Toco
    wheel spacers
    Hello all, this is going to most likely sound very ignorant but I was wondering if you can use an AAL kit more than once on a stock leaf pack, so add more than one leaf.
  2. Aug 5, 2018 at 6:01 PM
    GSPdog7
    GSPdog7 Well-Known Member
    Allen
    Central VA
    2015 Silver Sky Metallic TRD Off-road
    Even if you bought two of them like the 1.5” or 2” wheelers that’s over 200 dollars there...all pro and OME dakers are a couple hundred more and you’ll never have to touch them again. Buy once cry once. I would never stack two add a leafs that were the same size.
    2015 TRD Sport likes this.
  3. Aug 5, 2018 at 8:14 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Just buy a 3-leaf progressive AAL instead.
  4. Aug 5, 2018 at 8:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Yea, 1 add a leaf is all I would do, they need to all be longer than the next as well for them to function properly.
    Use a lift block if all you want is height.,
  5. Aug 5, 2018 at 8:19 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just buy a proper leaf pack.
    Been rocking a single 2in aal for a long while now on my stock 3+1 leaf pack.... its likely going to get replaced by some OME dakar mediums (EL095R) Axle wrap issues should be solved and it will be a much better spring pack.
    MattCowsmasher likes this.
  6. Aug 6, 2018 at 6:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Do it right by getting a leaf pack like others have suggested. Stacking aal's will do nothing besides you visiting the dentist for dentures. The ride quality will be jarring on an empty bed and avoid any lift blocks.
  7. Aug 6, 2018 at 6:24 AM
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I couldn't be happier with my HS 3 leaf progressive AAL. Ride is smooth as butter. YMMV
