Add a leaf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nightstriker, Apr 30, 2020.
  1. Apr 30, 2020 at 4:34 PM
    Nightstriker
    Nightstriker [OP] Well-Known Member
    2013 Tacoma Prerunner
    Hi TW, I own a 2013 Tacoma 2.7L DCSB. I am thinking about adding a leaf but in a different way. Do my friend has 2011 2.7L DCSB, he recently upgraded to newer leaf spring pack so I am planning to take a leaf from his old leaf pack and add it to mines. Is it possible?
  2. Apr 30, 2020 at 5:13 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    It's possible but won't help anything. Just a bit rougher of a ride
  3. Apr 30, 2020 at 5:36 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Not worth the work. Your time is worth more than the kit and result. The crappy leaf pack + $200 add a leaf kit will make an $800 bigger crappy leaf pack. Just save up for an upgraded lead pack. It only makes sense to add-a-leaf if the person doing the upgrade is a high schooler and his dad already has all the tools.
    It’s the same as buying a really damaged amplifier which caught fire, then having to buy all the soldering tools, o-scope, and cleaning chemicals to clean up the board and trying to teach yourself electronics repair. Not worth it.
  4. Apr 30, 2020 at 5:41 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Yep.
    If you actually plan on using your bed then just save for a new pack. AAL's are for those 'level' bros.
  5. Apr 30, 2020 at 9:26 PM
    Nightstriker
    Ok thanks
