add a rear sway bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stymie, Mar 28, 2020.
  1. Mar 28, 2020 at 12:17 PM
    stymie
    stymie [OP] New Member
    2012 Tacoma 2wd
    I would like to know if you can install sway bar on my tacoma truck. And any tips or clues to get er done.
  2. Mar 28, 2020 at 12:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  3. Mar 28, 2020 at 3:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Hellwig and Addco. Negative on the tips, except to follow their installation instructions. Oh, make sure to get the right one for lift you may have.
  4. Mar 28, 2020 at 4:43 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Do trucks benefit from a rear sway bar like a car does or are they detrimental to off road performance?
  5. Mar 28, 2020 at 7:17 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Most offroad trucks will remove the sway bar. Never drove a lifted tacoma w/ a rear sway bar, but I'm sure it couldnt hurt for street performance.
  6. Mar 28, 2020 at 8:10 PM
    badger
    badger Well-Known Member
    07 SR5
    Your truck will benefit from a rear bar if your truck understeers. The factors leading to understeer or oversteer are many, so no two vehicles are the same. You simply have to understand the concept and understand how to feel it in your vehicle. My truck understeered, so I installed a rear bar in 2012. It definitely improved the handling of my truck. It may or may not improve yours. Bear in mind that the rear bars for these trucks are very light compared to the front. The Helwig has three positions for the links which gives you a bit of tuning ability. The farther toward the end of the bar you connect the link, the smaller the effect. The bar I run has negligible effect on off road ability.
    I have to reiterate that I'm not suggesting you get one. It is a suspension tuning tool, so it only helps if you need it. If your truck already handles neutrally, or oversteers, adding a rear bar could actually be dangerous. If you have no clue what I'm talking about, spend your money on a stereo instead.
    Crosis likes this.
