ADD actuator issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mason912, Feb 23, 2025.
  1. Feb 23, 2025 at 3:31 PM
    mason912
    mason912 [OP] New Member
    2019 toyota tacoma 4wd
    3inch lift from dealership
    My “failure to change from 2wd-4wd” light came on in my tacoma . 2019 sr5 4x4 tacoma. I self diagnosed and then had a dealership diagnose, both came to the conclusion of a faulty ADD actuator. Got one online , i replaced it myself. When i got done replacing it, turned my vehicle on, it through abs lights , traction control lights, pre collision light was flashing, with no way of clearing them. I changed it back to the old actuator, all went away besides my failure to change light. Figured it was a faulty actuator, went and got another one, same thing. Any ideas or opinions
    I’m leaning towards a bad ECM but i don’t want to get ahead of myself and the toyota place in my area is subpar , i honestly don’t want to take it back.
  2. Feb 23, 2025 at 3:49 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Are you sure the transfer case is making its shift from 2WD to 4H successfully? It does that first before it does anything with the ADD.
    Toycoma2021 likes this.
