Add an additional media port??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SamsonStrongest, May 22, 2022.
  1. May 22, 2022 at 5:32 AM
    SamsonStrongest
    SamsonStrongest [OP] Member
    Hey all!
    I now have a 2021 Tacoma and I see there is only 1 USB port that allows media\Android Auto.
    (unless I am wrong)
    Is there a way to add an additional USB media port?
    Is there a USB splitter that would actually support both at the same time?
    End goal is to utilize both my USB stored music source and use Android Auto at the same time, as I have with other vehicles.
    My USB for music contains a large amount of media, so adding it all to my phone would not be desirable and simply just not possible.
  2. May 22, 2022 at 7:12 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    there are hardware usb splitters to physically select between 2 different usb devices at different times, but a usb splitter allowing multiple usb connections requires software to interface with the splitter, which i don't believe any oem head unit supports.
    so you're just SOL unfortunately, at least without changing the head unit, which is fortunately still possible in these trucks.
    vehicle designs generally take about 10 years to implement, which routinely puts the radio hardware about 5-10 years behind the current times, so it's a never-ending game of catchup!
    SamsonStrongest[OP] likes this.
  3. May 22, 2022 at 8:16 AM
    SamsonStrongest
    Bummer. Thanks for the details though!
  4. May 22, 2022 at 8:30 AM
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    You could try plugging in a USB hub to the existing data port to see what happens. That should tell you if the head unit supports multiple USB devices concurrently.
  5. May 22, 2022 at 8:35 AM
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    It may be worth uploading your files to YouTube music. I believe you can stream them even without a paid subscription.
  6. May 22, 2022 at 2:34 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Let us know if it work or not. I’m been looking for something similar as well.
  7. May 22, 2022 at 3:26 PM
    soundman98
    NW Indiana
    it would take a massive amount of digging, but i believe there was once a few threads like this. i recall running across one on a lexus forum once in an unrelated search about 8-ish years ago.
    it was a big list of hubs that don't work, might work, sometimes work, and work depending on HU OS version. iirc, there were 1-2 obscure brands that worked, and about a thousand that didn't or limited functionality...
  8. May 23, 2022 at 5:52 AM
    SamsonStrongest
    It's a 512 gb stick that almost full.
    That's why I don't it all on my phone, but also not sure if YouTube would allow all of it.
    Good suggestion though.
    Thanks.
  9. May 23, 2022 at 5:54 AM
    SamsonStrongest
    I can beleive it.
    I guess I just got lucky in my last ride.
    Just assumed this newer vehicle would be the same, if not better.
    Oops.
  10. May 23, 2022 at 8:56 AM
    ORtoCOTaco
    Colorado
    YouTube Music allows for up to 100,000 files to be uploaded, not sure how many files you have but still may be an option.
  11. May 23, 2022 at 9:11 AM
    SamsonStrongest
    Good to know. Thanks!
  12. May 23, 2022 at 9:23 AM
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
  13. May 23, 2022 at 9:29 AM
    SamsonStrongest
    I saw that one, but I can't find it available anywhere.
    After posting this thread, I see a lot of splitters explicitly saying they don't work with Android Auto or Apple Car Play.
    It's a bummer.
  14. May 23, 2022 at 9:55 AM
    CRCs Reality
    Pittsburgh-Ish
    And my lowly 2017 lacks either so I can't even test it to see.
