ADD and 4wd actuator spares package ! Price Drop to $250 !
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by dannybubbles, Jun 23, 2024.
  1. Jun 23, 2024 at 7:25 PM
    dannybubbles
    dannybubbles [OP] yada yada
    Daniel
    Chico, CA
    01 3.4 auto 4x
    If you like your ADD system, push button 4wd, and being prepared, I have the parts package for you!
    All removed from an old man driven smooth running 01 Tacoma, if he spent more than 100 miles in 4wd Id be flabbergasted.
    Package includes replacements for most of whats likely to go wrong electrically/mechanically in the field:
    *ADD actuator for the front dif
    *stub shaft and actuator collar(you beast you)
    *4wd actuator motor, gear, and plastic housing for the transfer case
    Im not including the metal housing or rod for the 4wd actuator because you have to split the case to remove it, and It seems unlikely to be the failure point anyways.
    Asking $250 for everything shipped conus from Vancouver Wa
    Open to offers if thats deemed unreasonable but Im hoping low miles OE equipment loving removed and known to work have value.
    Thanks
    D
    Madjik_Man, Speedytech7 and zippsub9 like this.
