ADD and transfer case actuator service?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by excorcist, Dec 13, 2016.
  1. Dec 13, 2016 at 4:15 PM
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    How many of you have "serviced" your ADD and transfer case actuator?
    I think this just consists of opening them up and cleaning / greasing them? what grease did you use?
    Did it help with shifting into / out of 4hi / lo ?
    Are they essentially the same thing?
    It looks like the ADD is pretty easy to remove, how about the t-case actuator?
    I haven't crawled under there to look myself yet, but having difficulty getting into and out of 4x4 and this seems to be a common area of dried up grease and things sticking that shouldn't.
    EDIT: I know the manual states not to open these, but it seems some simple preventative maintenance would do them some good considering what people are finding when opening them.
  2. Dec 13, 2016 at 4:18 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    tcase is super easy to get to (i havnt removed it but its RIGHT there with no obstructions)
    Front ADD.... thats probably more of a pain in the ass though.
    Id clean em out, grease em up and while i was there solder the motor leads so its not just a pressure connection.
    excorcist[OP] likes this.
  3. Dec 13, 2016 at 9:08 PM
    excorcist
    Reno, NV
  4. Jan 26, 2017 at 10:36 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    Hey bud, can you confirm where or what manual states do not open this add actuator up?? having trouble finding this info
    Thanks!
  5. Jan 26, 2017 at 10:54 AM
    excorcist
    Reno, NV
    I just Remember reading a couple threads that said it was not serviceable and if it was faulty the protocol is just replace it. Sorry I can't be more help.
    uurx[QUOTED] likes this.
  6. Nov 8, 2018 at 1:15 PM
    DC92T
    DC92T Well-Known Member
    03 TACO 33" BFD's SLOWPOKE
    Suspension lift, towing package with air bags rolling on 33" BFG A/T's
    I am still desperately searching for IF I CAN REMOVE TF Actuator?? I took out the bolts, it pulls out an inch and stops... I can never find the information when I need it the most....
    More than likely, I'm headed outside, in the dark, to ruin something else...
