Add another Lifted Taco!
Discussion in 'Suspension' started by Gooch814, Oct 20, 2010.
  1. Oct 20, 2010 at 6:37 AM
    Gooch814
    Gooch814 [OP] Well-Known Member
    Jeff
    Sumter SC
    04 Prerunner SR5
    5100's all around, Toytec coils, 2inch AAL. Deckplate mod. Westin Nerf Bars.
    I finally put my lift on yesterday and I couldnt be happier:D. I went with Billies all around set at 0 and went with Toytec AAL and Eibach coils. I will put pics up once I am out of work.
    --I do have a question though. I know your supposed to get an alignment after a lift but why exactly? My truck doesnt pull or anything, but I wasnt sure if theres another reason to get it aligned.
    Enlighten me please b/c I dont want to possibly damage anything, and I'll get those pics up asap. Thanks!
  2. Oct 20, 2010 at 6:40 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    you tease :) hurry up with those pics
  3. Oct 20, 2010 at 6:51 AM
    biscuits87
    biscuits87 Well-Known Member
    Will
    St J, VT
    10 TRD Off Road V6 6-speed
    Avid Light Bar
    When you lift a truck, you alter the factory alignment. Your wheels will actually be tilted slightly which could reduce the life of your tires among other things. So it is advised to get an alignment to correct this. Not necessary just a good idea.
  4. Oct 20, 2010 at 6:54 AM
    Gooch814
    Jeff
    Sumter SC
    04 Prerunner SR5
    Yup, I wasnt sure if it was just me put I thought my wheels did look slightly tilted in. I'll get it aligned after work and post up some pics.
    Now it's time to save and pick out wheels and tires!
  5. Oct 20, 2010 at 6:58 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    changing suspension components will wreck the fine (fine as in "small," not fine as in "exellent") adjustment on toe, caster, camber.
    The side effect of this is your tires will wear poorly.
    I actually had *negative* caster after I lifted, which made the truck feel squirrely. Without upper-control-arms my caster is still out of spec, but at least it's basically zero now.
  6. Oct 20, 2010 at 7:13 AM
    MyYota05
    MyYota05 Well-Known Member
    Muskogee, Oklahoma
    2005 Toyota Prerunner w/ TRD Offroad Pkg.
    3'' Lift Kit, Bed Rug Liner, Black Rims
    :worthless:
    Cant wait to see the pics. :D
  7. Nov 7, 2010 at 6:12 PM
    michaelg589
    michaelg589 Well-Known Member
    I need pics!!! :D
  8. Nov 7, 2010 at 6:15 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    You only have caster out of spec and you don't have ucas? :eek::p
  9. Nov 8, 2010 at 2:04 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    pictures please as i'm thinking of doing a simalar setup.
