ADD diff with manual hubs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZomBaja, Jan 24, 2016.
  1. Jan 24, 2016 at 3:20 PM
    ZomBaja
    ZomBaja [OP] Well-Known Member
    Dustin
    Central MS
    2002 Doublecab TRD Prerunner
    I've found an ADD front diff for my 4wd conversion, will this work just like that non add diff?
    As in, install front diff into truck, leave all lines and connectors unhooked and it will be ok?
    Or do I have to have the non add diff
  2. Jan 24, 2016 at 3:52 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    hmmmmm. i would think it engages the front driveshaft internally. you'd probably have to set the actuator to a permanently engaged position to use it. unless you wire it up to the inside of your cab and control the front driveshaft engagement that way. push button 4x4 instead of manual maybe?
  3. Jan 24, 2016 at 3:57 PM
    ZomBaja
    Dustin
    Central MS
    I would do a full push button swap, but I heard it's a huge pain and I haven't found a full parts list of what all is actually needed to do that swap
  4. Jan 24, 2016 at 4:02 PM
    CodeSeven
    Serge.
    Coachella Valley
    honestly if you have the diff on there with a good actuator, just make a custom wiring setup with a button in the cab somewhere. theres not very many wires on it, and im sure only 2 (maybe 3) of them will be needed. 1 for power 1 for ground and 1 possibly for signal telling the motor to engage.
  5. Jan 24, 2016 at 4:04 PM
    ZomBaja
    Dustin
    Central MS
    Ok, and aren't there vacuum lines on the diff? Where or what would i do with those
  6. Jan 24, 2016 at 4:06 PM
    CodeSeven
    Serge.
    Coachella Valley
    they might be vent ports. see if anyone can confirm this.
  7. Jan 24, 2016 at 4:07 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    My front diff has two breather lines. they are rubber in parts but they are not vacuum lines.
  8. Jan 24, 2016 at 4:09 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    If it the same as an 89-95 you just shift the actuator fork to engage and use a hose clamp to hold it in.
  9. Jan 24, 2016 at 4:11 PM
    ZomBaja
    Dustin
    Central MS
    Ok so, a switch would be easily doable.
    Then. Route my vent line anywhere.
    And add the ADD hubs to the truck instead of manual hubs?
  10. Jan 24, 2016 at 4:13 PM
    ZomBaja
    Dustin
    Central MS
    Also, this is the diff I will be buying
  11. Jan 24, 2016 at 4:13 PM
    CodeSeven
    Serge.
    Coachella Valley
    i would think that you can leave the manual hubs on there and engaged all the time, since the front is a differential and not a locker, and the front axle would be disengaged with the switch turned off.
    leave them on for looks? so long as the axle shaft fits in the wheel and the diff, i wouldn't change the hubs.
  12. Jan 24, 2016 at 4:14 PM
    ZomBaja
    Dustin
    Central MS
    Well I still have the 2wd hubs up front as it sits so I have to buy hubs regardless
  13. Jan 24, 2016 at 4:19 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    That thing is vacum engaged. You have to run these little vsv valves and electric to them.
  14. Jan 24, 2016 at 4:19 PM
    EB Group
    Rudy
    Halifax
    Right
  15. Jan 24, 2016 at 4:20 PM
    ZomBaja
    Dustin
    Central MS
    Well damn.....
  16. Jan 24, 2016 at 4:21 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    All the electronic sensor does on that diff it turn the light in the dash.
    Gonna be way easier to go all manual.
  17. Jan 24, 2016 at 4:21 PM
    EB Group
    Rudy
    Halifax
    Your electrical connector looks different than mine, what year it that one off of?
  18. Jan 24, 2016 at 4:21 PM
    ZomBaja
    Dustin
    Central MS
    96 4 runner
  19. Jan 24, 2016 at 4:23 PM
    EB Group
    Rudy
    Halifax
    Hmmm, different than mine for sure, mine is all electrical, no vacuum.
  20. Jan 24, 2016 at 4:26 PM
    CodeSeven
    Serge.
    Coachella Valley
    ohhhhh. hmmmm. youve got me on this one. where can we even get hubs for our trucks? 95-2000 parts list shows part numbers w/auto disconnect number 43502-04040, and w/o auto disconnect 4350204030. both are for 4wd.
