Add Drl to 2010 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtiro, Oct 27, 2024.
  1. Nov 21, 2024 at 10:53 AM
    caribe makaira
    Caribbean, Puerto Rico
    moon22[QUOTED] likes this.
  2. Jan 8, 2025 at 5:31 PM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Very very dumb question that I'm afraid to ask, but I'm a ways away from being able to actually verify as I'm held up on parts to get my trans back in (so..I have no starter at the moment). Tonight I finally finagled the tow package relay and harness in and buttoned things back up minus the lower dash panel/switches to test, but did not get DRL's when I keyed on; but does the engine need to actually be running (making the R in DRL rather literal), or should they work with ignition on/brake off?
    For better or worse, the Tacoma is the only vehicle whose DRL's I really like, and I've gone so far as to disable them in my daily...so I'll admit I've never paid the tiniest bit of attention to how they typically function. :oops:
  3. Jan 8, 2025 at 5:35 PM
    caribe makaira
    Engine running, parking brake released.
    moon22 likes this.
  4. Jan 8, 2025 at 5:40 PM
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Thank you for the sanity check - and again for the prior help!
  5. Jan 8, 2025 at 5:40 PM
    caribe makaira
  6. Jan 8, 2025 at 9:14 PM
    Taco_NW
    Taco_NW Member
    Tyler
    2010 Silver DCSB 4x4
    FWIW, I have a 2010 DCSB with factor tow option that I switched out to have DRL. Only had to replace the relay and the jumper and all worked fine and currently still does 6 yrs later.
    moon22 likes this.
  7. Jan 8, 2025 at 9:47 PM
    caribe makaira
  8. Jan 19, 2025 at 2:35 PM
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    This is an odd one. Finally got it back together enough to fire it up. Had the brake on and no DRL. I eased the brake off and saw that sweet, sweet amber light fire up my garage wall! Except now the brake will not turn them off. Dash indicator light for the brake works as it should.
    Another data point is that turning the parking lights on via the headlight switch does not dim them (and I forgot to check what happens with the headlights on now that I am typing this). Any ideas?
  9. Jan 19, 2025 at 3:39 PM
    caribe makaira
    DRL will turn off after engine off. No action after releasing parking brake and setting it again. It only activates them.
    Parking setting also does nothing, only low beams turns them off while engine on.
    moon22 likes this.
  10. Jan 19, 2025 at 4:44 PM
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Hmm so this is normal operation then; I was under the impression pulling the brake one click (or enough to activate the switch) would turn them off - but it only interrupts when starting the engine with the brake already on? Interesting.
    I'll probably wire a switch in then, was averse to it before but I already broke the "keep it absolutely bone stock" seal with the FJ transfer case conversion, hah..
  11. Jan 19, 2025 at 4:48 PM
    caribe makaira
    green with red stripe is the DRL activation wire. it's a ground.
    moon22 likes this.
