Add e-Locker 2nd Gen. SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wardjj, Mar 22, 2014.
  1. Mar 22, 2014 at 12:21 PM
    wardjj
    wardjj [OP] Active Member
    Joe
    MN
    2012 SR5 LB 4x4 LSD
    2012 SR5, 4x4, LB, 36kmi- This is probably a dumb question, I have searched for the answer but I can't find it. Can I buy an e-locker for my 2012 SR5? I gather it is an 8.4 diff. from what I read.
    I know everyone says to use the ARB, but the local guy did not want to go that way. An E-locker would probably be better for my use. Maybe I should just call East Coast.
    A second question would be, should I put it in the front since I have LSD in back? I guess that I have not looked for an e-locker for the front.
    Appreciate the input.
  2. Mar 22, 2014 at 12:29 PM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    elocker is an 8" ring gear and you'll need to transfer the entire axle housing and not just the 3rd. If you want to put the elocker in the front, you'll need a solid front axle. There's no elocker option for the IFS clamshell diff.
  3. Mar 22, 2014 at 12:32 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    ^ agreed. Plus the 8.4" rear end is stronger than the 8" especially if you were to swap to a arb or detroit locker. The only real locker option for the front would be an arb. Also 2012's don't have a mechanical lsd in the rear, only a brake based limited slip.
  4. Mar 22, 2014 at 12:47 PM
    rockgecko03
    Ben
    Rockwall, TX
    If you are going to get a locker, I would put it in the back. You may also want to look into the Yukon Zip locker for an air operated locker.
  5. Mar 22, 2014 at 12:53 PM
    wardjj
    Joe
    MN
    2012 SR5 LB 4x4 LSD
    I guess I got the impression that e-lockers were available for the T-100 which has the 8.4( I think), so I was thinking that might work in the SR5, but I have not seen anyone say that. Thanks you guys. Yukon or Arb for rear... is the solution then. Thanks a lot.
  6. Mar 22, 2014 at 1:24 PM
    rockgecko03
    Ben
    Rockwall, TX
    I'm almost positive the only elocker you can get for a toyota rear axle comes in the 8".
    Also, here's the difference in the axle housings between an non-elocker (top) and elocker (bottom)
  7. Mar 22, 2014 at 4:10 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Pretty sure eaton makes a e locker for the 8.4 rear.
  8. Mar 22, 2014 at 9:28 PM
    wardjj
    Joe
    MN
    2012 SR5 LB 4x4 LSD
    Jasmine- My guy said he had done a lot of lockers; usually Eaton or Detroit but, thought the air line itself was not as reliable. He is a reputable guy. I am in MN so, the cold might play a role. Thanks.
  9. Mar 22, 2014 at 9:32 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Cant you do some grinding on the 8.4 and get the elocker to fit?
