Add eFan to trans aux cooler?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015WhiteOR, Feb 24, 2015.
  1. Feb 24, 2015 at 7:13 AM
    2015WhiteOR
    2015WhiteOR [OP] Well-Known Member
    Gainesville TX
    I'm still in the warranty period so I'm trying to avoid modifying anything major on my 2015 TRD OR, but I want to make sure the transmission lasts as long as the engine. My last truck had an early death when the transmission started failing due to heat related degradation, despite regular fluid changes.
    Since the "tow package" cooler on these trucks isn't all that large, it seems like I could maybe wire in an electric fan with a sensor so it kicks on when rock crawling or stuck in a traffic jam when it's 100*F out.
    When I'm out of the warranty period I'll upgrade the radiator itself to something larger or plumb in another one in series.
    Has anyone had any luck adding a fan?
  2. Feb 24, 2015 at 7:18 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I don't really think it is necessary unless you are pulling heavy loads a lot. Just crawling around the trans temps shouldn't get that hot. The transmissions on this truck are overbuilt for the application. They were originally designed to go behind the old tundra's v8.
  3. Feb 24, 2015 at 7:40 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    This.
  4. Feb 24, 2015 at 7:38 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yup.
